Changed Headlights, now they flicker/low power
Postby steve1606 [OP] » April 10th 2009, 12:02am
Hi, I recently bought a 92 safari. Seems like every week it costs me 300$ to repair something so far. The other day I changed the headlights to install brighter ones(planning a 5000km drive). Since ive changed them the new ones almost always have very low power and sometimes flicker. Sometimes 1 works fine, sometimes its the other. I checked the plug that goes into the lights, doesnt seem to be this...any thoughts? im new to these vans and to mechanics in general
92 Safari 4.3 V6
steve1606
Years of Membership: steve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full yearssteve1606 has been a member for 12 full years
Re: Changed Headlights, now they flicker/low power
Postby astro355 » April 10th 2009, 12:34am
I would check the plugs again. Sounds like you have some corrosion in there.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full years
Extra Info: 355 V8 700R4
Postby steve1606 [OP] » April 10th 2009, 4:33am
yeah theres corrosion a bit everywhere on this van except for the body. should i try changing the plug?
92 Safari 4.3 V6
steve1606
Postby astro355 » April 10th 2009, 2:07pm
If you wanted but I don't think that is necessary. Just use a small screwdriver or pick and scrape the connectors for the headlight terminals. Even use WD-40.
astro355
Postby Farmer » April 10th 2009, 6:26pm
crc also makes an electrical connection cleaner in a spray can
'86 Astro shorty, rwd, 8 pass, 4.3 v6, Auto trans
'81 Bronco, 6" lift, 35" tires, Solid axle conversion
RESPECT THE VAN!!!
Farmer
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Farmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full yearsFarmer has been a member for 12 full years
Postby steve1606 [OP] » April 10th 2009, 10:59pm
sweet, thanks guys ill have another 100q's for u guys later
92 Safari 4.3 V6
steve1606
It is currently June 25th 2021, 11:50am
Comments: 64
Date: Jun 23 '21
Time: 6:52am
Ken2.7
Comments: 39
Date: Jun 18 '21
Time: 10:16pm
SoccerMom4x4
Date: Jun 17 '21
Time: 1:30am
joeg
Date: Jun 16 '21
Time: 11:56pm
Date: Jun 16 '21
Time: 10:47pm
