Electric engine fan thermostat
Postby mchevalier [OP] » August 24th 2013, 1:52am
Hello all,
I recently installed an electric engine fan on my 01 Astro. Second one I've done it to. Better MPG and power on both.
For the fan thermostat I used a sensor pushed through the radiator. I would like to put the sensor in the coolant, the water outlet seams like a good place.
I'm trying to find a water outlet that will fit the 4.3 and have a threaded hole for a sensor. I've thought about drilling and threading the existing but the metal on those is not very thick. I've seen some for small blocks that come with a threaded hole I could put a brass plug in and thread that for the sensor, 8 x .75.
Or are there any unused plugged holes on the engine or manifold suitable for what I'm doing?
mchevalier
Years of Membership: mchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full yearsmchevalier has been a member for 7 full years
Van Model Year: 2001
Extra Info: 2WD cargo
  • PCM Electronic Fan Control...
    by WinnieVan » August 24th 2020, 8:21pm in Electrical
    Last post by stent View the latest post
    September 24th 2020, 8:56pm
  • Engine stays revving after highway run
    by smokinjoe » May 30th 2020, 1:58am in Electrical
    Last post by M_a_t_t View the latest post
    May 30th 2020, 3:06am
    18
    October 25th 2020, 5:22am
Re: Electric engine fan thermostat
Postby Drummernaut » August 24th 2013, 2:41am
There is an unused port available on the passenger side head.
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Postby chevymaher » August 24th 2013, 2:56am
Postby DRZ » August 24th 2013, 6:59am
Doesn't that plan only work after the thermostat opens? At least that is how the setup I made from scratch for the LS1 Astro works.
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full years
Topics: 53
Images: 55
Alias (AKA): HPbyStan
Extra Info: awd cargo Alloys
It is currently October 25th 2020, 5:22am
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Users browsing this forum: No registered users and 27 guests
