97 Astro fuel pump wiring harness
Postby hiker108 [OP] » August 29th 2013, 9:01pm
My 97 astro van fuel pump harness has square 4 pin connector....2 black, one grey and one purple wire. New fuel pump came with flat 4 pin harness. Does anyone know how the pins match up between the connectors. I've heard the flat connector was developed because of a heating issue.
hiker108
Years of Membership: hiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full yearshiker108 has been a member for 10 full years
Extra Info: 4.3L V6 AWD
Re: 97 Astro fuel pump wiring harness
Postby chevymaher » August 29th 2013, 9:54pm
hiker108 wrote:My 97 astro van fuel pump harness has square 4 pin connector....2 black, one grey and one purple wire. New fuel pump came with flat 4 pin harness. Does anyone know how the pins match up between the connectors. I've heard the flat connector was developed because of a heating issue.
I been dealing with this on other vehicles in my work. There should be a small piece of paper in the fuel pump box that tells you how to splice the wires.
It is currently February 26th 2021, 10:37am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
cron
