TAIL LIGHTS/TEMP CONTROL LIGHTS/INSTRUMENT CLUSTER LIGHTS
Postby jnbgoch [OP] » May 14th 2009, 7:53pm
Okay guys, I've just found this site. Wish I'd found it a year ago! Looking for help and to help if I can.
Problem is: I have turn signals, brake lights and headlights. I don't have tail lights, instrument lights, and temp control lighting. Also, my overhead console, odometer and radio dim unless I use the dome override.
Fuses are good, headlight switch is good. (I tested this by swapping in a new switch at Autozone before buying it and nothing changed)
I'm at my wits end with this. Anybody got a clue as to what is wrong?
Thanks in advance.
Brad
:confused: :banghead:
(oYo) Chevy Astro LT
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: jnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full yearsjnbgoch has been a member for 11 full years
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
  • Temp, fuel, some lights working/not on dash
    by Hiker2187 » October 21st 2020, 5:20pm in Electrical
    October 22nd 2020, 7:13pm
  • Tail light wiring issues
    by Dbleeger » November 19th 2020, 12:59am in Electrical
    November 28th 2020, 4:43pm
    9
    67
    March 4th 2021, 11:01am
Re: TAIL LIGHTS/TEMP CONTROL LIGHTS/INSTRUMENT CLUSTER LIGHTS
Postby gtkane » May 15th 2009, 12:51am
What year you got?
I've got the GM service website up right now, and I'll look it up.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby jnbgoch [OP] » May 15th 2009, 4:58pm
Sorry, knew I forgot something. 2000 astro...
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
Postby 'cudapaul » May 16th 2009, 6:05am
1. Check the fuses under the dash.
2. The 2000 and up models have a sensor in the right side of the defroster grille on top of the dash (see little bump) that automatically turns on the lights when it gets dark. Do you have anything laying on top of it? A quick test is to rotate the IP brightness control next to the head light switch to see if it changes the brightness of the overhead console display.
If none of these apply then you have some trouble shooting to do. We'll be here to help.
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby jnbgoch [OP] » May 16th 2009, 6:45am
thanks for the info. Tomorrow I'm gonna go through all the fuses again and check all the bulbs. I know the sensor you are talking about, nothing is covering it. The dimmer is turned all the way up and turns on the dome when it reaches the top as it should. Could this be a relay somewhere?
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
Postby jnbgoch [OP] » May 17th 2009, 7:10am
FINALLY!!! Decided to take another look through the fuses. Turns out that fuse #9 in the under dash fuse box READS parking lights. It was blown and also operates all the lights I was having problems with. (tail lights, instrument lights, radio/overhead console, temp control) I found all this out by going through the fuse box again while reading the manual. Now all I have to do is get the cat. conv. changed and get smog tested!
Thanks to those who replied.
Brad
:doh:
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
Postby 'cudapaul » May 17th 2009, 5:13pm
So the question is, why did the fuse blow?
Since you have a 2000, you will have a trailer wiring harness in the rear where the jack is stored. Might want to check it to make sure that the wires are still taped off.
'cudapaul
Extra Info: LT AWD
Postby jnbgoch [OP] » May 17th 2009, 6:42pm
Funny you should mention that. The house I moved into has a steep driveway. The first few times pulling into the garage basically tore apart my trailer wiring. That has also now been repaired and I have learned to go in at an angle when I do pull into the garage, which is not very often.
Thanks,
Brad
175,000 miles
jnbgoch
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 7
Images: 8
Alias (AKA): Brad
Extra Info: LT
Postby m1a » June 10th 2010, 6:37am
Hi, Similar problem on my 2001. Those same lights go out when nighttime arrives. The IP and other interior lights work fine when the ignition switch is in the accessory position, or when there is daylight. This has been intermittent, but is now a big problem. Starting to get battery drain issues, and low idle now (idle due to low voltage ???)
m1a
Years of Membership: m1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full yearsm1a has been a member for 10 full years
Extra Info: LS Ext
It is currently March 4th 2021, 11:01am
OldSchoolNoe
Comments: 0
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 22
Date: Feb 17 '21
Time: 4:26am
