Temp gauge & ignition switch?
Postby Mr_Bowtie [OP] » May 16th 2009, 3:09pm
#1 Question:
How hot does your Van get on the temp gauge? Mine only goes up to the 1/4 mark. I would think it would be more towards the middle of the gauge, but want to see what you guys think?
I do have an external tranny cooler...maybe thats helping out?
Its fine for now, but just want to be ready come fall if it possibly needs a new thermostat.... :mrgreen:
#2 Question:
My ignition switch won't turn towards me, so I can't listen to music while parked. Do I just need a new ignition switch? If so will a standard chrome one out of a '89 Camaro work(gotta it left over... :lol: ) ?
Thanks, Nick.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
  • Dead In The Water (no power to ignition)
    by 1992safari » August 24th 2020, 1:07am in Electrical
    August 25th 2020, 1:45am
  • Ignition switched power source under hood
    by snailsafari » September 4th 2020, 10:45pm in Electrical
    Last post by Sailing_Faith View the latest post
    September 6th 2020, 6:12pm
    19
    September 19th 2020, 12:28pm
Re: Temp gauge & ignition switch?
Postby 'cudapaul » May 16th 2009, 5:09pm
Sounds about right for the temp gauage, they are NOT accurate at all. However, it is common for the thermostat to fail open and then the coolant temp never gets correct, which woudl give a lower temp reading like yours. If you have plenty of heat after teh engine has fully warmed up, and can feel warm air from the heater vents within a few minutes of starting up in normal weather then the thermostat is probably OK.
I don't think the Camaro ignition switch will work. The M/L van has the actual switch mounted on top of the steering column under the dash and when you rotate the lock cylinder with a key it actuates a gear that pushes the ignition switch up or down.
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby Mr_Bowtie [OP] » May 18th 2009, 2:45am
The heat seems fine, but its only 50 degrees out....... :lol:
So, you think its the box "thingy" that the ingnition rod goes into? That sucks cause I just had a junk S10 steering column I swap out of a old truck I had and I threw that "thingy" out with it! :banghead:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby gtkane » May 18th 2009, 4:42am
The Camaro switch is the same...but that's not your problem.
At some point in time, the coloumn was apart, and the ignition rack was assembled one tooth out.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby Mr_Bowtie [OP] » May 19th 2009, 2:10am
Ahhhhhh..........I will have to fix that. Gotta have my tunes while waiting for the kids to get out of school! :mrgreen:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby Mr_Bowtie [OP] » May 29th 2009, 6:33am
Well instead of messing with the steering column.....I just wired my CD player hot all the time. Now I can listen to the tunes without my keys. :lol:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby adibv5 » June 21st 2009, 1:41am
anyone think that i can couse serious damage if keep running at 230-240degrees? when i have ac on the temp hits 230 no ac is around 190/
adibv5
Years of Membership: adibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full years
Postby Mr_Bowtie [OP] » June 21st 2009, 2:11am
I would say she is running pretty hot. Is it running that hot on the highway? What temp thermostat are you running? 190*?
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby adibv5 » June 21st 2009, 3:22am
its 180. and i have an extra trans cooler ,
problems i know is that the catalytic converter code comes up i get around 11miles per gallon its a awd and construction van i carry full load.
the temps are on idle when i start driving its around 210. with no ac on is much cooler.. also ambient is around 80 90.
adibv5
Postby Matrixx » June 22nd 2009, 7:13am
If that is a correct reading from the temperature sending unit, then it's "way" to hot. Check the thermostat for faults, then check the radiator to make sure it isn't plugged up.:)
Matrixx
It is currently September 19th 2020, 12:28pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
