short
short
Postby Necrocom4 [OP] » May 30th 2009, 12:22pm
ive been having to deal with a short somewhere for about a year now. it drains the battery very slowly. ill take my dvom and itll read 12.56 and a day later itll read 12.43. i kind of ignored it for awhile cuz i thought my alternator would charge it enough so it wasnt an issue but i dont drive it everyday anymore. theres been a few times where i had to get a jump from people at work or itll stall out at traffic lights and not have enough juice to start back up again so its getting quite annoying.
ive tried the fuse method where you take out a fuse one at a time and check to see where its shorting and so far ive got every fuse out of the panel and all of the relays and the battery is still being drained. its not the battery cuz when i disconnect the cables the voltage will stay put. the alternator charges the battery at 14v so right now im stumped.
Necrocom4
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Necrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full yearsNecrocom4 has been a member for 12 full years
Topics: 9
  • Short in electrical
    by Joseph Leon » May 2nd 2020, 7:59pm in Electrical
    May 2nd 2020, 8:37pm
    27
    October 28th 2020, 6:30am
Re: short
Postby astro355 » May 30th 2009, 8:34pm
So just to make sure, when you connect/disconnect the positive terminal on your battery, does it spark?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: short
Postby Necrocom4 [OP] » May 31st 2009, 5:24am
no spark. i still have all the fuses out so i dunno if it should change if i put them all back in.
Necrocom4
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Re: short
Postby astro355 » May 31st 2009, 5:59am
If you have a parasitic draw on the battery, you should see a spark when you are reattaching the positive battery cable. Leave the headlights on, disconnect the battery and then reconnect the battery. That will let you see what you are looking for. Then you can put each fuse in one at a time and then drag the positive connector of the positive terminal of the battery.
astro355
Re: short
Postby Necrocom4 [OP] » May 31st 2009, 3:10pm
ok it sparks when i have the headlights on but it doesnt when i tried it with the fuses. im thinking the draw is so slow theres no reaction.
Necrocom4
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Re: short
Postby astro355 » June 1st 2009, 2:17am
If there is any draw, it will spark. Try it with the interior lights on instead of the headlights. The spark will be smaller but definitely still there.
astro355
Re: short
Postby kml » October 13th 2009, 2:15am
Sorry ar about your trouble! I have a similar problem and have had to resort to using a switch on the positive terminal. It is a real pain in the butt to have to pop the hood every night, but that is the only resolution to the problem that seems to work. As you stated, I am sure that the draw down is very small, butover a few days unused, it leads to a depleated battery. I do notice that the radio clock is always on though. Is that normal??
kml
Years of Membership: kml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full yearskml has been a member for 11 full years
Alias (AKA): Kurt LaTRAY
Extra Info: 4.3L 2wd
Re: short
Postby astro355 » October 13th 2009, 7:38am
The radio clock stays on with the ignition off all night? That is not normal.
astro355
Re: short
Postby webcat » October 13th 2009, 8:27am
Something you could check!
Its pretty common to have your lightbulb in your glove box get stuck on and when they do you cant see that its on from the outside
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
It is currently October 28th 2020, 6:30am
Time: 4:29am
Comments: 9
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
