97 Safari AWD Will NOT Crank, Speedo Stuck at 100
Postby diehard [OP] » July 9th 2009, 6:31pm
approx 250k miles on engine, new plugs wires cap rotor ect. car has been sitting for a few weeks. only noise i hear when i turn the key is the starter relay in fuse box.
Battery is fairly new, tried to charge it and wont even attempt to crank, should i try hitting the starter with a hammer or put 12 volts directly to the starter? If the starter is bad what tools/size sockets do I need to change it.
Thanks
diehard
Years of Membership: diehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full yearsdiehard has been a member for 11 full years
  • Flickering odometer, then won't crank.
    by Halfdozen » January 17th 2021, 4:12pm in Electrical
    Last post by Halfdozen View the latest post
    January 19th 2021, 4:26pm
  • Crank no start, help with diagnostic
    by nic.can1 » April 15th 2021, 3:48am in Electrical
    Today, 1:48am
    48
    April 17th 2021, 4:31am
Re: 97 Safari AWD Will NOT Crank, Speedo Stuck at 100
Postby rev_les » July 10th 2009, 1:26am
First off check your grounds, at the battery, and at the engine and chassis.By check them, I mean disconnect and clean them, make sure there's not any corrosion in the connectors or terminals, or contact points, make sure everything's nice and clean, and well connected. You have an odd combination of problems, so I'd start at the grounds. ( check the engine for additional grounds from the wiring harness). Others will be on later and will help out if they can as well.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
It is currently April 17th 2021, 4:31am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
