another electrical question
Postby ghostrider1061 [OP] » July 27th 2009, 4:27am
every once in awhile when i turn on my headlights my right turn signal lite comes on in my dash. no blink but steady burn. i can drive a couple miles or so turn my lites off do my thing, come back start my van and turn on my lites no turn signal lite . sounds like a short somewhere in my wires but where. switch? turn signals? taillites/ parking lite mode? in park mode is where it comes on. :banghead:
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
  • Curious electrical issues, getting worse fast.
    by kittenflaps » May 1st 2020, 9:54pm in Electrical
    Last post by kittenflaps View the latest post
    May 23rd 2020, 12:54pm
  • Short in electrical
    by Joseph Leon » May 2nd 2020, 7:59pm in Electrical
    May 2nd 2020, 8:37pm
    9
    49
    October 20th 2020, 12:32pm
Re: another electrical question
Postby astro355 » July 27th 2009, 4:29am
I think you have a bad ground somewhere.
When you turn the headlights on, is one head dimmer than the other? With brights also?
And happy birthday.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby ghostrider1061 [OP] » July 27th 2009, 5:37am
the lites are ok. low beam and high beam.
ghostrider1061
Topics: 17
Alias (AKA): d j
Postby astro355 » July 27th 2009, 5:43am
Either way, electricity always takes the easiest path to ground. Circuits are built around that premise. Unfortunately, if the desired path to ground suddenly offers for resistance than normal (ie, bad ground, cut wire, wires rubbing on each other) the current will find another path to ground and take it. If the current goes thru a circuit with a light, it will activate that light.
Is there any other work you have done to the van recently, regardless of what the work was? Any other odd things happening to it?
astro355
Postby ghostrider1061 [OP] » July 27th 2009, 5:56am
it needs a complete going over. i have a coolant leak somewhere,an oil leak, oil gauge don't work gas gauge don't work doghouse doesn't tighten like it should(threads stripped out). a/c don't work(needs vaccumed and charged) fan motor don't work. but with all the things that are wrong with it, she still fires up and is a dependable daily driver. i would not hesatate to drive from coast to coast in her. mite be a little hot inside due to the doghouse, but she would make it no problem. she has over 200k on her, i am on her third trip around showing about 3k on her clock. she just needs tlc or a overhaulin by chip foose. :chevy: :driving: :banana:
ghostrider1061
Topics: 17
Alias (AKA): d j
Postby Big_kid » July 27th 2009, 2:18pm
Check your turn signal/tail light bulbs & make sure they're the proper type, installed correctly(not backwards) and tight. My dad's Caprice did something similar once. Somehow an 1156(single filament) found it's way into a tail light socket. Every time he stepped on the brake, the parking lights would come on. That circuit was being backfed through the socket with the 1156 bulb.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
It is currently October 20th 2020, 12:32pm
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Maddog
Date: Oct 08 '20
Time: 8:19pm
