1996 Astro Blower Resistor Harness
Postby mdemarco2009 [OP] » August 7th 2009, 8:12pm
Hello and thank you in advance for any help received.
My blower resistor and harness recenty burned up. I removed the resistor and cut back the harness. Unfortunatly i did not make note of which wire goes where and the replacement harness has all gray wires. Can anybody snap a picure of their harness so i can see where which wire goes? A wiring schematic woud be nice or if someone could just list the order. Thanks!
mdemarco2009
Years of Membership: mdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full yearsmdemarco2009 has been a member for 11 full years
  • Is This The Trailer Wiring Harness? How Do I Route It?
    by ri$e*above » July 10th 2020, 2:56am in Electrical
    July 11th 2020, 4:23am
  • No Power to Tow Harness
    by SportsBoy » July 16th 2020, 8:10pm in Electrical
    Last post by SportsBoy View the latest post
    July 26th 2020, 2:25am
    52
    September 24th 2020, 5:36am
Re: 1996 Astro Blower Resistor Harness
Postby ASTROJOE LT1 » August 8th 2009, 2:42pm
Here is the diagram with the resistor wire colors and the heat circuit. I hope this helps.
http://www.autolib.diakom.ru/CAR/Chevrolet/1997/Astro/SYSTEM%20WIRING%20DIAGRAMS/9278.pdf
89 ASTRO CL Shorty,95 Corvette LT1 Engine,4L60E, 3.42 Gears with a Torsen Posi,Black on Gray ( Original Color )
ASTROJOE LT1
Years of Membership: ASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full yearsASTROJOE  LT1 has been a member for 12 full years
Images: 8
Extra Info: 95 LT1 Engine
Postby mdemarco2009 [OP] » August 9th 2009, 3:51am
Thank You!111111
You have no idea how much this helps.
mdemarco2009
Postby webcat » August 9th 2009, 4:11am
Thank you from me too! Thanks ASTROJOE LT1
I needed that diagram!
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
It is currently September 24th 2020, 5:36am
Time: 5:39pm
Date: Sep 22 '20
Time: 8:04pm
Gabor Latte
Comments: 19
Date: Sep 18 '20
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
