OBD-II connection not working
Postby hamiltonfighter [OP] » January 26th 2014, 3:10am
I stopped by Autozone to have a check engine light read. The Autozone worker hooked up the reader and it wouldn't show any messages.
I might go to another location and see if maybe it was just the worker not knowing what he was doing.
Does our van have a way to display the check engine messages?
hamiltonfighter
Years of Membership: hamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full years
Topics: 33
Images: 5
  • HELP! TPS and MAP sensor connection mistake?!
    by observer » November 19th 2020, 8:19am in Electrical
    Last post by dcsleeperdcsleeper is online! View the latest post
    November 20th 2020, 9:00pm
  • wipers not always working
    by daj120388 » July 8th 2020, 11:14pm in Electrical
    July 8th 2020, 11:49pm
    30
    November 25th 2020, 3:26am
Re: OBD-II connection not working
Postby plymouthcranbrook » January 26th 2014, 4:47am
Check your fuses, most likely the power point fuse. We had a Cavalier that the OBDII had no power to and that was the problem.
plymouthcranbrook
Years of Membership: plymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full years
Topics: 16
Extra Info: allwheel drive
Postby hamiltonfighter [OP] » January 26th 2014, 8:45am
Where is the power point fuse? Is it in the fuse box under the dash? Is there a label next to it?
hamiltonfighter
Topics: 33
Images: 5
Postby plymouthcranbrook » January 29th 2014, 4:29am
Used to be called the cigarette lighter. Check you manual, I don't remember which it is on the Astro
plymouthcranbrook
Topics: 16
It is currently November 25th 2020, 3:26am
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
Users browsing this forum: WildBoregoWildBorego is online! and 16 guests
