electrical problems
electrical problems
Postby briannaomi [OP] » October 4th 2009, 3:08am
I have a 2000 chevrolet astro awd and when I turned the heater control switch from off to any other position I would immediately lose power to my fuel gauge, temperature gauge, front blower, rear blower, rear defroster and overhead display for mileage, temperature, etc. as well as my digital odometer. It used to kick back on after a while once I turned it back to the off position, stay on for a while and then kick back off. It would always kick off instantly whenever I changed the heater control from the off position. What should I be looking for here? Any ideas?
briannaomi
Years of Membership: briannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full yearsbriannaomi has been a member for 11 full years
  • Electrical issues
    by alohavan » April 15th 2020, 6:53pm in Electrical
    April 18th 2020, 4:25pm
  • Curious electrical issues, getting worse fast.
    by kittenflaps » May 1st 2020, 9:54pm in Electrical
    Last post by kittenflaps View the latest post
    May 23rd 2020, 12:54pm
    October 1st 2020, 5:20am
Re: electrical problems
Postby Matrixx » October 4th 2009, 9:03am
This sounds like a short in the switch itself. Pull the assembly out from the console and check the back of it for any burn marks and current draw with a meter. This would be the first place I would check, then work out from their. The heater motor can also draw a heavy amount of power if it's seized or worn but check the switch first as mentioned. Let us know how things are going, Thanks.:)
Matrixx
Postby 8fox » July 2nd 2015, 4:28am
Hi, I had a similar problem in my 2001. All of those circuits run through the ignition switch. I tore apart my whole dash looking for a short or disconnected wire. Took it to a shop and they traced to the Ignition switch.
Hope this helps.
8fox
Years of Membership: 8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years8fox has been a member for 9 full years
Extra Info: AWD LS
It is currently October 1st 2020, 5:20am
gordo999
Date: Today
Time: 12:58am
Date: Sep 29 '20
Time: 4:52pm
Date: Sep 24 '20
Time: 8:52pm
Date: Sep 23 '20
Time: 5:39pm
Date: Sep 22 '20
Time: 8:04pm
Users browsing this forum: No registered users and 17 guests
