2nd Ignition ?
2nd Ignition ?
Postby webcat [OP] » October 18th 2009, 5:30pm
Why is there a 2nd ignition circuit ?
I was thinking the 2nd ignition circuit powers the same thing as the main ignition circuit but is just there in case the first ignition circuit fails , am i right?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • Battery draining with the ignition off
    by JimmyUp » November 22nd 2020, 4:44pm in Electrical
    Last post by Big_kid View the latest post
    November 24th 2020, 4:02am
  • Stuck ignition key after starter repair.
    by petema » January 29th 2021, 12:08pm in Electrical
    February 15th 2021, 9:11pm
    36
    April 13th 2021, 10:47pm
Re: 2nd Ignition ?
Postby toddb » October 18th 2009, 6:35pm
I really doubt that it is a redundant circuit. That usually is only done on aircraft. Prolly just another system needed to start the truck and GM decided to split the two different circuits.
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Re: 2nd Ignition ?
Postby evil_motors » October 18th 2009, 9:53pm
could be for remote start or an alarm system
1992 GMC Safari XT , Rhinolined interior, Fatmat walls and celing, Racing seats, Satin Black Dash, Taplock, Clear Corners, Check out my continuing thread with all my mods and lots of pictures.
https://www.astrosafari.com/viewtopic.php?f=9&t=3769
evil_motors
Years of Membership: evil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full years
Topics: 26
Extra Info: XT RWD
Re: 2nd Ignition ?
Postby webcat [OP] » October 19th 2009, 1:39am
:confused:
webcat
Topics: 253
Re: 2nd Ignition ?
Postby Big_kid » October 19th 2009, 1:40am
Could it be to power more circuits than one wire can supply? :shrug:
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Re: 2nd Ignition ?
Postby moneymaker » October 19th 2009, 3:56am
the two wires they are showing(one pink, and one white) sounds like the same color wires that go to the ignition coil. and normally you can pick up tach signal from the white wire if i remember correctly.
moneymaker
Years of Membership: moneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full years
Topics: 7
Re: 2nd Ignition ?
Postby webcat [OP] » October 19th 2009, 9:11pm
nope , the diagram is refering to actual ignition wires at the ignition switch!
webcat
Topics: 253
Re: 2nd Ignition ?
Postby webcat [OP] » October 20th 2009, 5:25am
Big_kid wrote:Could it be to power more circuits than one wire can supply? :shrug:
You might be on to something!
webcat
Topics: 253
It is currently April 13th 2021, 10:47pm
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
