95 IGN fuse panel forr???
Postby 95twotone [OP] » March 1st 2014, 9:00pm
What is the IGN in the fuse panel for?
The van stopped starting, there are wires everywhere from a hack remote starter install, traced the TWO that came from the IGN location and found they have been disconnected. Just tested for power at the harness and the starter, its reading 10.8v. (I thought that's what the IGN went to??)
Gonna pull and test the starter now.
Any help, thoughts, or ideas are welcome; this is starting to drive me nuts. And its cold outside (canada. winter. pita.)
95twotone
Years of Membership: 95twotone has been a member for 6 full years95twotone has been a member for 6 full years95twotone has been a member for 6 full years95twotone has been a member for 6 full years95twotone has been a member for 6 full years95twotone has been a member for 6 full years
Re: 95 IGN fuse panel forr???
Postby chevymaher » March 1st 2014, 10:49pm
It is hot when the key is in the run position.
I use it as the control circuit to run my electric fans.
It is empty untill you use it for something.
Postby 95twotone [OP] » March 1st 2014, 10:55pm
THANK YOU! One of the owners added all kinds of stuff and the electrical is scary. This helps me a TON with my no start issue. Just pulled the starter and am going to test it inside.
95twotone
Postby 95twotone [OP] » March 2nd 2014, 7:06pm
just to close incase any one was wondering it was the startor. Went from running fine to completely dead. Died on a morning after a humid cold snap.
95twotone
It is currently January 19th 2021, 9:07am
OldSchoolNoe
Date: Today
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
