fuel pump only primes sometimes, everything else works
Postby breakurnees [OP] » March 15th 2014, 7:49pm
2001 Safari cranks but won't start sometimes. When it does start, it runs fine and stays running. Most of the time when it starts it will run for days turning over on the first try. Sometimes though, I turn the key, don't hear the fuel pump, and then it cranks but won't start. The horn and all lights work, the gauges all work, battery voltage and oil pressure look fine. It seems like this could be a cold day or dampness problem. It seems to like to start on hot days, but that could be coincidence.
I've searched and find similar threads, but no clear indication of what to start looking for first. The PO says he put in a new fuel pump not long ago. There are some wires with non factory butt connectors near the gas task on a cylinder shaped molex looking thing.
Any help, known problems would be great.
breakurnees
Years of Membership: breakurnees has been a member for 6 full yearsbreakurnees has been a member for 6 full yearsbreakurnees has been a member for 6 full yearsbreakurnees has been a member for 6 full yearsbreakurnees has been a member for 6 full yearsbreakurnees has been a member for 6 full years
Van Model Year: 2001
  • Help! Voltage drain with new everything! 1998 astro
    by CoffeeBee » June 18th 2020, 12:46am in Electrical
    Last post by rootbeer99 View the latest post
    July 16th 2020, 4:12am
  • Fuel pump question??
    by dave1950 » May 4th 2020, 6:42pm in Electrical
    Last post by dave1950 View the latest post
    May 7th 2020, 12:04am
    88
    October 26th 2020, 2:41am
Re: fuel pump only primes sometimes, everything else works
Postby Astrofarian » March 16th 2014, 5:37am
You may be onto something with your observations re: the connectors. Wonder what else got butchered ? MAY not be your problem here but that's where I would start. Good luck!
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby breakurnees [OP] » March 16th 2014, 7:05pm
Should the gas gauge drop to zero when I turn the key?
breakurnees
Postby redfury » March 17th 2014, 2:42am
replacement pumps require a new plug to be wired in, you'll probably have to look at that.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby RECox286 » March 17th 2014, 2:52am
Yeah, the fuel level will drop off, b/c when you go to the START position, it supplies 12v
to the starter, period. When the key drops back to RUN, then 12v is resupplied to all the
accessories. Check out the wiring diagram for any US made vehicle with a keyed ignition
switch system. Usually there will be a BYPASS wire that supplies the ignition system from
the starter solenoid so you get spark in START.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby breakurnees [OP] » March 17th 2014, 2:02pm
Do fuel pumps die by becoming unreliable at startup? I've never had it die on me while running.
breakurnees
Postby redfury » March 17th 2014, 4:14pm
Yes, if you look at my Delphi fuel pump review, you can see the old pump motor and why it stopped working for me. Depending on the electrical motor, the contact points for the brushes vary from 6-8 contact points. If you only have 6 contact points, then the motor can only park in 3 positions to restart the motor. On mine, there was only one place the motor could have parked and started back up , which it didn't and caused my no start condition.
viewtopic.php?f=27&t=41946&start=20
redfury
Topics: 53
Images: 13
Postby breakurnees [OP] » March 17th 2014, 7:57pm
That's not what I wanted to hear, but thanks. Is it reasonable to just replace the strainer, filter and motor? The rest of the assembly is working.
breakurnees
Postby chevymaher » March 17th 2014, 8:26pm
breakurnees wrote:That's not what I wanted to hear, but thanks. Is it reasonable to just replace the strainer, filter and motor? The rest of the assembly is working.
Yes it is. I used to do it working for various shops. E bay sells the pump only. Parts places don't sell it, except the entire Enchillada. Got to be a business and know people to get just the pump. So you can charge for the Whole Enchillada and put in only the pump.
It is currently October 26th 2020, 2:41am
Leeann_93Leeann_93 is online!
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Users browsing this forum: No registered users and 15 guests
