Mystery connectors
Mystery connectors
Postby oman [OP] » March 28th 2014, 3:45pm
So the van is a 2004, dutch doors, rear heat and air. I have a mystery connector in my jack storage compartment, that is disconnected, but both ends are there. Obviously, it is meant to connect the thingamabob to the worlydoo…. But it would be nice if someone knew what the thingamabob or worlydoo actually were.
17625
oman
Years of Membership: oman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full yearsoman has been a member for 8 full years
Topics: 30
Images: 7
Re: Mystery connectors
Postby SilverBullet1997 » March 28th 2014, 5:28pm
I think that is where you plug in the vaporizer. :rockon:
:obscene-smokingweed:
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby Silverhawk » March 28th 2014, 5:44pm
17289. I like Bullets answer better but, if the fan doesn't work on your rear AC/Heater then it has probably been unhooked for some reason. Plug the two together and see if it work then.
Silverhawk
Years of Membership: Silverhawk has been a member for 6 full yearsSilverhawk has been a member for 6 full yearsSilverhawk has been a member for 6 full yearsSilverhawk has been a member for 6 full yearsSilverhawk has been a member for 6 full yearsSilverhawk has been a member for 6 full years
Topics: 25
Images: 13
Postby SilverBullet1997 » March 28th 2014, 5:45pm
Silverhawk wrote:17289. I like Bullets answer better but, if the fan doesn't work on your rear AC/Heater then it has probably been unhooked for some reason. Plug the two together and see if it work then.
I believe that is on the other side of the van Hawk.
SilverBullet1997
Topics: 54
Images: 247
Postby gavio » March 28th 2014, 6:05pm
Well, when that plug isn't shunting power from the nuclear reactor over to the driveshaft fluid reservoir, it is used to hook up a door jamb switch in the liftgate - this from the FSM showing black and yellow wires going to just such a switch...... My 04 has it disconnected as well....
gavio
Topics: 77
Images: 4
Postby Astro Pop » March 28th 2014, 8:38pm
It is the wiring for trailer lights. GM put it in the vans in case a trailer hitch was installed.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby oman [OP] » March 28th 2014, 9:57pm
So it's almost definitely not for the flux capacitor? Bummer.
Thanks guys.
oman
Topics: 30
Images: 7
Postby Astrofarian » March 28th 2014, 10:10pm
Hi...Yeah door pin-switch connector or POSSIBLY rear-window defrost? But then you are in Colorado so you probably HAVE a working defroster (or WISH you did?). But DEFINITELY NOT the flux capacitor! THAT would be connected to the optional power ashtray sending-unit. LoL
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby CoolCat4Christ » March 28th 2014, 10:21pm
oman wrote:So it's almost definitely not for the flux capacitor? Bummer.
Thanks guys.
Astrofarian wrote:Hi...Yeah door pin-switch connector or POSSIBLY rear-window defrost? But then you are in Colorado so you probably HAVE a working defroster (or WISH you did?). But DEFINITELY NOT the flux capacitor! THAT would be connected to the optional power ashtray sending-unit. LoL
Your wrong.....your all wrong. I found the Flux Capacitor tucked behind the panel just in front of the jack storage compartment. Plugged it in and Voila. Only problem is now my MPG went down dramaticaly. Guess that's why GM unplugged it. Oh and beware your dealing with 1.21 gigawatts of power to fire this puppy up!!
Here it is in action.
17553ImageImage
"If guns cause crime, all of mine are defective." -Ted Nugent
CoolCat4Christ
Years of Membership: CoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full yearsCoolCat4Christ has been a member for 7 full years
Images: 7
Location: Born In East L.A. Currently residing somewhere in the San Gabriel Valley of Southern California
Van Model Year: 2002
Extra Info: LS 4.3l RWD
Postby sfeaver » March 28th 2014, 11:02pm
When that baby hits 88 MPH your going to see some serious s**t!
Just watched all three back to the futures a couple weekends ago with my daughter.. Good movies still after all these years!
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby SilverBullet1997 » March 28th 2014, 11:09pm
sfeaver wrote:When that baby hits 88 MPH your going to see some serious s**t!
You are the 4th person I have talked to in the last couple of weeks that just re-watched these movies? I am starting to notice a pattern, or a conspiracy a brew..... :think:
Anyways, sorry to turn your serious thread in to a zoo, oman. Who knew this would happen... :shrug: Wait I guess I did.... :rofl: and maybe I meant for it.... :banana:
SilverBullet1997
Topics: 54
Images: 247
Postby CoolCat4Christ » March 28th 2014, 11:21pm
SilverBullet1997 wrote:
.....Anyways, sorry to turn your serious thread in to a zoo, oman. Who knew this would happen... :shrug: Wait I guess I did.... :rofl: and maybe I meant for it.... :banana:
SilverBullet1997.......Image.....said.....Image......"a zoo".......Image
17553ImageImage
CoolCat4Christ
Images: 7
Postby CoolCat4Christ » March 29th 2014, 2:00am
On the serious side Oman Image
Astrofarian got me thinking. Came across this.
Maybe the plug is for a rear door switch. Who knows?? :shrug:
17553ImageImage
CoolCat4Christ
Images: 7
Postby sfeaver » March 29th 2014, 2:48pm
Your on to something.. That switch used to be on the top of one of the lift supports, but I know in at least 2001 it had been eliminated. 97 has it though, but would be wired differently as there is no BCM.
sfeaver
Topics: 29
Images: 21
Postby CoolCat4Christ » March 29th 2014, 3:44pm
sfeaver wrote:Your on to something.. That switch used to be on the top of one of the lift supports, but I know in at least 2001 it had been eliminated. 97 has it though, but would be wired differently as there is no BCM.
That wiring diagram is listed as year 2004
I found this one listed as year 2000. After the year 2000 the Lift Gate Strut Switch is removed from diagram. Looks like the "Mystery Plug" may be for the cargo door models????? Thoughts anyone?
17553ImageImage
CoolCat4Christ
Images: 7
Postby CoolCat4Christ » March 29th 2014, 4:08pm
Ok kiddies,
The case of the "Mystery Plug" has been cracked. Stuck a meter on the plug and 12v is present. Jumped the contacts and didn't get this
instead the interior lights came on. So it appears the plug is for a door/strut switch. So this makes it alot easier if you want add to some sort of switch to turn on lights when opening the lift gate. Which is what I is gonna do.
Special thanks to Oman for finding that confounded plug, Astrofarian and Sfeaver for pointing the right direction and the Zoo for keeping this thread going.
17553ImageImage
CoolCat4Christ
Images: 7
Postby gavio » March 29th 2014, 6:04pm
I've found a couple different places in the 04 FSM that show the wiring for courtesy lights that aren't present in the newer vans, such as the this rear courtesy light switch, the glove box light, stepwell lights, and the lights on the doors.... Actually, I'm not sure if the reflectors in the doors were ever lighted, but the manual shows them....
Sometimes, the wiring is still intact, others, like the doors, it's been eliminated...
gavio
Topics: 77
Images: 4
Postby CoolCat4Christ » March 29th 2014, 9:17pm
gavio wrote:I've found a couple different places in the 04 FSM that show the wiring for courtesy lights that aren't present in the newer vans, such as the this rear courtesy light switch, the glove box light, stepwell lights, and the lights on the doors.... Actually, I'm not sure if the reflectors in the doors were ever lighted, but the manual shows them....
Kinda glad Oman posted this. I was gonna add a switch, run a wire to the slider door switch to activate interior lights when hatch is opened. having the wiring there makes it so much easier.
Lights for the door reflectors sounds like something i'd like to add just for kicks.
17553ImageImage
CoolCat4Christ
Images: 7
Postby gavio » March 29th 2014, 9:19pm
Me too..... But so far I haven't seen one in the P&P that had lights there......
gavio
Topics: 77
Images: 4
Postby CoolCat4Christ » March 29th 2014, 9:36pm
gavio wrote:Me too..... But so far I haven't seen one in the P&P that had lights there......
Hmm wonder if they ever produced any with reflector lights. I'll have to check it out when i'm at the P&P
17553ImageImage
CoolCat4Christ
Images: 7
It is currently November 29th 2020, 9:32pm
DbleegerDbleeger is online!
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Users browsing this forum: Google [Bot] and 4 guests
