Starter or ignition switch?
Postby Eddie_S [OP] » May 9th 2014, 5:00pm
Intermittently (maybe every 50th start) but otherwise with no pattern the 2005 Astro won't crank. Everything electrical works. Sometimes if I switch it off and back to start it works, other times nothing. Happens warm or cold with the same frequency. Can the switch be temporarily bypassed to rule it in or out as the cause?
Eddie_S
Years of Membership: Eddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full yearsEddie_S has been a member for 9 full years
Extra Info: 4.3L V6
  • Question about the starter
    by bradaskins » June 1st 2020, 7:43pm in Electrical
    Last post by AstrofarianAstrofarian is online! View the latest post
    June 2nd 2020, 2:00pm
  • Dead In The Water (no power to ignition)
    by 1992safari » August 24th 2020, 1:07am in Electrical
    August 25th 2020, 1:45am
    9
    22
    October 22nd 2020, 3:59am
Re: Starter or ignition switch?
Postby Lumpy » May 9th 2014, 10:09pm
It "can" be bypassed. But if it's only failing every 50th time then you'd have to to a lot of bypass starts to get any kind of meaningful data. And that would wear down your battery pretty quick.
On the back of your starter solenoid there's three terminals. Two are very large, one small. One of the large terminals leads TO the starter itself. The other large terminal is a large gauge wire coming from the battery and to the alternator. The smaller terminal is from your ignition key switch.
Shorting the BATTERY/ALT terminal to the IGNITION terminal will bypass the ignition key and spin the starter. It won't start the car unless the ignition key is in the ON position but it will spin the starter motor.
Be careful down there. Car in PARK, eBrake set, chocks on the wheels, cellphone in pocket to call 911 if you arc weld yourself to the bottom of your van or if it rolls over you. Much safer would be a "remote start switch" that some use when doing a tune up. It's a simple hand held switch with alligator clips that does exactly as the above.
Probably worth checking to see that those three terminals are all tight, not corroded etc. To do that, disconnect the battery FIRST. You're going to be swinging metal wrenches around in a tight spot and they will be connected to 12v+. Very simple to touch ground by mistake.
Could be your ignition key switch ($35 plus a new switch at my local locksmith). Could be the starter solenoid (replace cost simple to lookup at vendor of your choice, usually replace starter AND solenoid but sometimes you can just replace the solenoid). Could be the wiring between the ign switch and the various places it goes. That one would probably be the most frustrating one to track down.
It is currently October 22nd 2020, 3:59am
nwisehart
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Users browsing this forum: Google [Bot] and 8 guests
