These showed up today
Postby Jasen [OP] » December 16th 2009, 5:18am
Hella iron blue w/ amber beam fog lights
Planning on mounting them in these then hook them to the steering with choke cables.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Re: These showed up today
Postby $uperJoe » December 16th 2009, 5:23am
why are you hooking them to the steering wheel with cables
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby Jasen [OP] » December 16th 2009, 5:42am
$uperJoe wrote:why are you hooking them to the steering wheel with cables
Oh Joe, I expected more from you <hanging head low and shaking, sigh>
:lol:
I've had the idea for years to have some lights the turn with the wheels to help see while going around corners.
Mrs. Boss is getting a new set of 6" lights for the Wrangler. The narrow set lights on that thing suck, and being a soft top the A pillar along with the soft top make for a huge blind spot, you really have to look around, so I'm going to do hers first. It's a lot easier to do and work out any bugs in my idea. Then I'll pull the bumper mask on the Van and cut out the recesses to mount my lights.
200k
Ultra gauge
Topics: 260
Images: 101
Postby $uperJoe » December 16th 2009, 5:46am
i assumed that was the reason. i guess i expected more of you to wire it in off some relays and use a modified blinker switch instead of some wire and pully contraption as gilligans professor would do. just kidding. whats your idea for making this work together
$uperJoe
Topics: 59
Postby Jasen [OP] » December 16th 2009, 5:53am
Nice return :lol:
I figure I'll hook the choke cable to the pitman arm or maybe drag link, then to one light and either run a cable to the other, or use a solid rod between them.
I'll use a long arm on the lights with a bunch of holes in it to hook the cable up and be able to adjust the amount of travel of the lights.
200k
Ultra gauge
Topics: 260
Images: 101
Postby $uperJoe » December 16th 2009, 6:02am
i was confused about the idea it seams. i thought it would be to turn on a fixed light. not have a rotating light off the steering.. that should be neat. instead of a solid mount like a bar that connects them i think the cable will work better. so there is some available adjustment in the system and if there is bumps in the frame it wont transfer to shakey lights. have you thought about maybe hydraulic power. like a slave cylinder from a clutch for each light and a master off your pitman arm?
$uperJoe
Topics: 59
Postby Jasen [OP] » December 16th 2009, 6:07am
Hadn't thought about hydraulics. Your probably right about connecting the two with cable. I went with sleeved pillow blocks figuring that would be a good solid mounting system.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Jasen [OP] » December 16th 2009, 6:09am
I wonder if some small car clutch slaves would work.
200k
Ultra gauge
Topics: 260
Images: 101
Postby $uperJoe » December 16th 2009, 6:10am
where will they be? like on top of the bumper, in factory location, under the air dam?
$uperJoe
Topics: 59
Postby Jasen [OP] » December 16th 2009, 6:13am
I'm going to cut out the two outer recesses in the bumper mask below the license plate
200k
Ultra gauge
Topics: 260
Images: 101
Postby Jasen [OP] » December 16th 2009, 6:23am
Or maybe an ACME thread rod and a drive motor.
200k
Ultra gauge
Topics: 260
Images: 101
Postby $uperJoe » December 16th 2009, 6:27am
:rofl: ACME :rofl: if you go that route make sure to use an unusually long rope and some sort of balancing act (meep meep)
$uperJoe
Topics: 59
Postby Big_kid » December 16th 2009, 2:13pm
Don't forget the anvil! (Let's not use any dynamite on this project) :lol:
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby Munken » December 16th 2009, 7:03pm
Citroën ID/DS and SM had that in the 70s. And there is on the C5 now. I do not know how they have done it, But Citroën have always been fond of the hydraulics. I like your idea :thumbup:
Have you thought about throttle wire for boats? They tend to be thick and strong. ;)
"Nothing is impossible, the impossible just takes a little longer"
Munken
Firing on 5 Cylinders (L2)
Years of Membership: Munken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full years
Topics: 69
Alias (AKA): Munken the lunatic
Extra Info: LT 4.3L V6 RWD
Postby Jasen [OP] » December 17th 2009, 4:31am
Lexus of Infinity did it a few years ago. I think it's wired into the on board GPS.
As far as I know, this was the first.
The center light turned with the steering.
I figure with a self lubricating bearing there shouldn't be much resistance and the choke cable should be strong enough. But that's why I'm doing the Wrangler first. If I do need to make design modifications, it'll be easy on the Wrangler.
200k
Ultra gauge
Topics: 260
Images: 101
It is currently October 27th 2020, 4:38pm
stentstent is online!
Date: Today
Time: 4:29am
Comments: 9
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
