i need this thing to run
Postby workinVan [OP] » December 22nd 2009, 9:03pm
low down
new battery check
new starter check
new cables from battery to starter and ground check
new cps check
charging the battery at this moment
in that order
my starter just barely spinning won't turn over currently, it did before the new cables once while using the block heater but had an electrical burning smell which i think might be the new starter as there was some "oil" on it at the bottom of it which was very clean and not from the truck with 150000 unmaintained mileage its way dirtier
reading about halfway between 8 and 14 on the battery guage
i bench tested the starter and it does turn
i believe i drained down the original battery while cold starting it so replaced it quick but the new one may not have been fully charged hopefully thats it but....
what am i not considering?
i need this truck for work and am not making any money while i sit here so please as soon as you read this throw some education at me i've been reading any posts related on this issue i could find
2000 cargo 4.3 v6 W rwd, a/c, G80, silverstars, hood struts, magnaflow cat
and a big honkin air filter....possibly for sale make an offer
workinVan
Years of Membership: workinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full years
Topics: 9
Alias (AKA): notjim
Extra Info: 4.3 rwd cargo
  • Need some help!
    by 90astro » August 10th 2020, 12:47am in Electrical
    Last post by 90astro View the latest post
    August 11th 2020, 2:43am
    January 28th 2021, 3:28am
Re: i need this thing to run
Postby $uperJoe » December 22nd 2009, 10:02pm
do you have another car with jumper cables or try to hook both batteries up with jumper cables and see if it spins faster
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby workinVan [OP] » December 23rd 2009, 1:23am
well after plenty of testing i took the starter back and got it replaced it spins now and cranks over.
the problem now seems to be that the engine just doesn't want to fire as if its fuel isn't there so now i get to figure that out
workinVan
Topics: 9
Alias (AKA): notjim
Postby workinVan [OP] » December 23rd 2009, 4:22pm
starter fluid not working must be a spark issue
thanks all for the help
workinVan
Topics: 9
Alias (AKA): notjim
Postby workinVan [OP] » December 23rd 2009, 7:29pm
so i changed the coil because there is no spark and still isn't.
anybody have any idea what would be causing this?
please anybody whos experienced this what can cause the coil to not send power,it is new and so is the wire from it to the distributer
?!???!!??? :feedback: :pray:
workinVan
Topics: 9
Alias (AKA): notjim
Postby $uperJoe » December 23rd 2009, 10:56pm
check the spark module in the bottom of the distributor
$uperJoe
Topics: 59
Postby workinVan [OP] » December 26th 2009, 11:34pm
new plugs,wires, dist cap,and rotor added during a christmas eve rain storm and i still can't get spark through the wiresto the plugs. anybody have a clue what could prevent that from working and what to test to figure out why?
workinVan
Topics: 9
Alias (AKA): notjim
Postby workinVan [OP] » December 27th 2009, 7:56pm
ok people i went and got a code reader cuz i needed one and i'm getting a code p0336 generic crank pos sensor A circuit range performance.
its a new sensor and had the same code for the old sensor.
any ideas how to fix this i.e. new wiring to the sensor or what?
anybody know how to test the wiring? :banghead:
workinVan
Topics: 9
Alias (AKA): notjim
Postby workinVan [OP] » December 28th 2009, 2:35pm
well it runs now changed the brand new cps with another brand new one and yay
thanks for nothin
workinVan
Topics: 9
Alias (AKA): notjim
Postby astroturf » December 28th 2009, 3:21pm
workinVan wrote:well it runs now changed the brand new cps with another brand new one and yay
thanks for nothin
Ya See, that's part of being in a forum. Maybe it's the first occurrence of this problem here. And now "You are the Man" for fixing and logging here what you found. So, from myself, A Big Thank You. To follow up with a fix is appreciated. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby rev_les » December 28th 2009, 6:26pm
Sometimes it takes time for the right person to be on here and read a particular problem as well, and being a holiday weekend, a lot of folks aren't around.Many of us have been on here chasing a problem, logging what we tried, and what worked and didn't, so that next time, someone can look up a problem and have an easier time of it. Always read the codes BEFORE you spend a dime on a single part, and yes, new parts can be defective, which is why so many on here recommend OEM parts, as they have a better standard to pass before they're used on any given vehicle in the first place. If the CKPS gives you that code again, check or replace the plug to it, and look for chafed wiring or wiring broken inside the insulation.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby workinVan [OP] » December 28th 2009, 7:08pm
rev_les wrote:Sometimes it takes time for the right person to be on here and read a particular problem as well, and being a holiday weekend, a lot of folks aren't around.Many of us have been on here chasing a problem, logging what we tried, and what worked and didn't, so that next time, someone can look up a problem and have an easier time of it. Always read the codes BEFORE you spend a dime on a single part, and yes, new parts can be defective, which is why so many on here recommend OEM parts, as they have a better standard to pass before they're used on any given vehicle in the first place. If the CKPS gives you that code again, check or replace the plug to it, and look for chafed wiring or wiring broken inside the insulation.
thanks for trying to be nice but i've been posting for a week with only one response
a i am broke, oem = no house payment for me and i use this truck to make my living so i haven't been making any money.
b i'm working in my driveway in freezing conditions cuz i don't have a garage
c i didn't get that code until 3 days after trying to diagnose, none before hand
just imagine how my holiday week has been, so pardon me for being frustrated
maybe next time i'll just be as insulting as possible in the beginning so i get responses quicker :blah: :blah: :blah:
workinVan
Topics: 9
Alias (AKA): notjim
It is currently January 28th 2021, 3:28am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
markmitchmarkmitch is online!
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
Users browsing this forum: Yandex [Bot] and 18 guests
