Van cut off while driving?
Postby lastastro [OP] » December 25th 2009, 10:45pm
1999 astro van 4.3 cargo, Van just cut off while driving in good dry weather no rain,etc things I have replace.
1. Fuel pump month ago.
2.First thing that I did was to check fuel pres, 60 psi
3. Check ign, on the coil check out fine.
4. replace ign pickup in dist. got power to it.
5. replace, rotor,dist cap, got power to it.
6. Have hot battery.
7. replace fuel filter
I check all fuses, ok, move relays around, I took out the plug wire from the coil to the dist and grounded it out I have fire.
I have no fire coming from and plug wire from the dist.
please advise
lastastro
Years of Membership: lastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full yearslastastro has been a member for 10 full years
Re: Van cut off while driving?
Postby ihatemybike » December 26th 2009, 4:02am
Spark coil to dist, but not dist to wire. Sounds like it's grounding out somewhere. Might be a bad cap/rotor. Off brands seem to live short lives in these vans.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full yearsihatemybike has been a member for 11 full years
Topics: 68
Postby rev_les » December 26th 2009, 5:56am
I've seen off brand rotors glaze at the contact point from the coil wire..try lightly sanding the contact point with fine sandpaper, if it fixes it, replace it with a Delco part. (Don't keep driving it like that because it'll do it again)
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby lastastro [OP] » December 26th 2009, 12:12pm
After installing all of these part I have not yet had it running? It will not crank I not getting any fired out of the dist, but from the coil it's working,,
Thanks, you say ground where should I start checking ground parts, lights, gauges, radio, and turning over is very strong?
lastastro
Postby lastastro [OP] » December 27th 2009, 1:41am
:rockon: I was getting fired out of my coil, but decided to pull off the coil, dang that was fun took some reading on the coil and it was weak, got a new one and made sure it was grounded good. Put it back together turn on the key fired right up. Thanks for all the input..
lastastro
It is currently October 21st 2020, 1:56pm
nwisehart
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
