I am not sure if it is worth trying to fix the van or not, but figured I would try to get some help.
First off: 3 days ago my right turn signal quit blinking in the dash, it lights up steady. I figured a bulb blown out on that side.
Second: Left Side turn signal quit working with same symptoms.
Third: Dome light stays on. I changed that out about a year ago to LEDs. Right now the LEDs are partially lit when everything is off. If I open a door or turn on the dome light switch, the dome light will fully light. When door is closed and switch is off, the dome light is dim.
Fourth: Alarm is going off for no reason. 3 times yesterday, 2 times today while I was standing next to the van.
Everything else seems to be working properly. It seems I have a short somewhere causing the battery to drain. When the alarm senses a drain, it goes off. I'm not sure if the turn signals are related to the problem or not.
I did take the fuse out for the horn/dome. I lost the use of the stereo, horn, alarm, and dome light. Now everything has been wired up the same for over 3 years.
Any ideas?
And just for information. It is a 1989 Astro with a 250amp alternator and 2 batteries. It does have a high powered stereo in it. Like I say, everything else seems to work properly. I'm believing the problem is in the dome light / horn circuitry, but not sure.
I've got a line on a 1994 Astro for $200 which has no problems. I just don't want to give mine up just yet.
