This is the factory harness connector for the power points and cigar lighter from a '97. I use this if I happen to have the console off anyway during interior diagnostics. It beats having to hook up to the battery and drag the cable(s) either over the doors or over the engine if you have the doghouse removed. Can also be used with male terminal jumpers for quick tests of any of the climate controls. Do not use for testing of window motors or power seats. Next time I see the other end in the boneyard I'm going to grab it and make a quick connect for my test light. Just a thought. :2:
This is the factory harness connector for the power points and cigar lighter from a '97.[ [url=http://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=13229] ][/url] I use this if I happen to have the console off anyway during interior diagnostics. It beats having to hook up to the battery and drag the cable(s) either over the doors or over the engine if you have the doghouse removed. Can also be used with male terminal jumpers for quick tests of any of the climate controls. Do not use for testing of window motors or power seats. Next time I see the other end in the boneyard I'm going to grab it and make a quick connect for my test light. Just a thought. :2:
Good thought. Also a good use of an existing point for testing. Thanks. Jim
23.2K members
