should my rear wiper switch have backlight?
Postby red98tj [OP] » February 3rd 2010, 5:37pm
I have no backlighting on my rearwiper/wash switch. it is a 2000 astro.
Vehicles:
2005 Chevy Avalanchesold
2000 Chevy Astro AWDsold
2003 Chrysler T&C AWD
2003 GMC Yukon XL 2500 Quadrasteer
2007 Chrysler Pacifica awd
2012 Keystone Outback 312bh
red98tj
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: red98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full yearsred98tj has been a member for 11 full years
Topics: 10
Alias (AKA): kevin
Extra Info: LT AWD
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    October 12th 2020, 10:54pm
  • Blower Motor, Wiper, Rt Turn Signal Dashlight GREMLINS
    by SlowRider » June 12th 2020, 9:06pm in Electrical
    Last post by SlowRider View the latest post
    June 14th 2020, 3:29am
    7
    20
    October 25th 2020, 9:39am
Re: should my rear wiper switch have backlight?
Postby rev_les » February 4th 2010, 3:27am
My '99 doesn't have a back light in it either.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Jasen » February 4th 2010, 3:46am
Neither does my 97, or it's never worked :shrug:
Let me check my FSM
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby unrreal » February 4th 2010, 3:52am
yes its supposed to have a light, in my 99 it just burnt out, the bad thing is that they dont sell just the bulb, you have to buy the whole switch, i went to the junkyard and i took one apart and all there is to it is a filament led (you know the ones u find at radio shack )
unrreal
Years of Membership: unrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full years
Topics: 22
Images: 12
Extra Info: 4.3L LS AWD
Postby Jasen » February 4th 2010, 3:53am
The 97 FSM doesn't show in indicator for the rear wiper.
200k
Ultra gauge
Topics: 260
Images: 101
Postby sfeaver » February 5th 2010, 12:09am
There is supposed to be. Mine works... Need a whole new switch or try to put in a new light. I think one of the bulbs in mine is burnt out, although its not the greatest picture in the dark.
Scott
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby red98tj [OP] » February 5th 2010, 2:24am
Thanks, I think I will try to take it apart to see if I can solder in a new bulb.
Vehicles:
red98tj
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Alias (AKA): kevin
Extra Info: LT AWD
Postby Gus_Mahn » February 14th 2010, 2:51am
LED's have a one way polarity. Be sure that you have the polarity right before soldering in the LED or it will not function. You can use a 9V battery to figure out which is positive.
Gus_Mahn
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Gus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full years
Topics: 10
It is currently October 25th 2020, 9:39am
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
