How to replace the ignition switch?
Postby g0t0pless [OP] » February 13th 2010, 11:02pm
I've searched through 15 pages of search results for "ignition switch" with nothing pertaining to replacing the switch.
A new switch is only $11 at Pep Boys, and my key feels like its going through peanut butter when I insert it. I want to replace it before it completely fails, but I'd like to see a write up on how to replace it before I dig into it myself.
Thanks.
g0t0pless
Years of Membership: g0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full years
Topics: 50
  • Dead In The Water (no power to ignition)
    by 1992safari » August 24th 2020, 1:07am in Electrical
    August 25th 2020, 1:45am
  • Ignition switched power source under hood
    by snailsafari » September 4th 2020, 10:45pm in Electrical
    Last post by Sailing_Faith View the latest post
    September 6th 2020, 6:12pm
    92
    September 19th 2020, 1:37pm
Re: How to replace the ignition switch?
Postby tedanderson » February 14th 2010, 12:24am
I'll see if I can find my old full size van book and scan the pages. But it's a pretty easy and straight forward process.
1. Disconnect the battery, turn the key to the ON position and pull the steering wheel. (which you will probably have an airbag that needs removal as well)
2. Get a steering column lock plate removal tool. (available as a loaner tool)
3. Insert the tool into the slots on the lock plate.
4. Once you tighten down the lock plate tool, it will expose the lock ring. Remove the lock ring and then remove the tool and the lock plate will come out of the column.
5. This is where things start to get a little hazy for me.. I recall removing the retaining screw which is inline with the ignition switch itself. (it's a phillips screw) and then the switch came right out and I had to disconnect the wires on the end of it. What I am not sure of is whether I had to remove the turn signal guts to get to it.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby Big_kid » February 14th 2010, 4:34am
Before you pull it all apart, squirt some Ronsonol (cigarette lighter fluid in the yellow & blue bottle) into the lock cylinder then run the key in & out and turn it back and forth a few times. This will break up any dirt buildup in the lock. Pull the key out & wipe it with a paper towel, repeat several times. If after this it still feels like you need some grape jelly and a glass of milk, then replace it.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 331
Extra Info: 2WD 5.7 V8
Postby g0t0pless [OP] » February 22nd 2010, 11:04pm
I decided to try and repair it before replacing it. A little squirt of WD40 fixed it right up. Now it works like new.
g0t0pless
Topics: 50
Postby astro355 » February 23rd 2010, 2:28am
Oh, I see. You're having(had) problems with the ignition cylinder, not the ignition switch. :mrgreen:
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Astrofarian » May 8th 2014, 5:39am
This may be an old/ghost thread but thought maybe bumping it may shorten someones search for this info.
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby tedanderson » May 8th 2014, 10:46am
:thumbup: Good bump.
tedanderson
Topics: 76
It is currently September 19th 2020, 1:37pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
