oil gauge wiring question
Postby $uperJoe [OP] » February 16th 2010, 3:18am
how can i find out if my gauges are positive trigger or neg trigger? the safari is having the wiring done tonight and gauge function is important to me. i am using the sending unit from the 96 5.7 sfi and the factory gauge from the 95 safari. when the gauge is all hooked up and key is energized the oil pressure maxes out before any pressure is there. once started stays pegged. only thing i can think is maybe the dash gauge is neg signal and the other one is pos signal. any thoughts. also i will post the gauge diagrams if anyone needs them for reference
note the oil is new and i am not letting it run more than one min at a time as i have no coolant in the system or even the hoses hooked up yet
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
  • Erratic Fuel Gauge
    by scanmanvt » July 16th 2020, 7:03pm in Electrical
    Last post by crittermo View the latest post
    July 28th 2020, 12:12am
  • Using Block Heater Stops Temperature Gauge From Working
    by Danver » November 7th 2020, 4:33am in Electrical
    Last post by Danver View the latest post
    9
    30
    November 25th 2020, 2:58am
Re: oil gauge wiring question
Postby webcat » February 16th 2010, 3:37am
wont a 1995 sending unit work?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby $uperJoe [OP] » February 16th 2010, 3:39am
havent looked yet. headed out back to check
$uperJoe
Topics: 59
Postby webcat » February 16th 2010, 3:45am
I dont know if this will help but i once used a 1995 complete TBI system including 1995 sending unit with a 1996 guage and it did'nt work , i then changed to a 1996 sending unit and the guage started working!
webcat
Topics: 253
Postby $uperJoe [OP] » February 16th 2010, 5:17am
ok ill swap it i guess and let you know what happens. they look the same though. same plugs and wires and even color of wire in the same location. for clarification its a 4.3 w, not the Z that is tbi
$uperJoe
Topics: 59
Postby webcat » February 16th 2010, 5:41am
Mine looked the same too.
webcat
Topics: 253
It is currently November 25th 2020, 2:58am
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
Users browsing this forum: Google [Bot] and 8 guests
