Pass Through Grommets - Rear Body Floor
Postby Lumpy [OP] » September 15th 2014, 6:57pm
A while back we were discussing how to get wires from the interior to the exterior at the rear of the van. Here's the grommet for the trailer wires I was talking about. LEFT rear inside, pull the plastic rear A/C cover, on the floor next to the A/C pressure hoses.
There's one on the RIGHT side as well. Has a knockout like an electrical wiring box. Mine was partially knocked out, "coin" still hinged on. I plugged it with a more appropriate rubber plug.
  • Harness Clip Rubbing Through
    by TBLBill » October 22nd 2020, 1:14pm in Electrical
  • 2000 Astro rear Dutch Door won't open
    by mglsite » November 16th 2020, 8:21pm in Electrical
    November 24th 2020, 2:05am
    April 15th 2021, 6:36pm
Re: Pass Through Grommets - Rear Body Floor
Postby 97cargocrawler » September 15th 2014, 8:54pm
I too have fed wires through that area but I didn't see any knockouts!
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Lumpy [OP] » September 15th 2014, 9:04pm
Those wires in mine are to the trailer hitch, which I've never used. Perhaps interesting to note that I've got, presumably from factory:
ONG (looks red in the pic) = Hot In Run Power
DGRN = RIGHT Stop/Turn light
BRO/WHI = Tail/Running lights
WHI = Ground
Odd that the RIGHT but not LEFT stop/turn is wired.
Postby Astrofarian » September 16th 2014, 11:28pm
Lumpy wrote:Those wires in mine are to the trailer hitch, which I've never used. Perhaps interesting to note that I've got, presumably from factory:
WHI = Ground
Maybe the P.O. failed the "Turning Left with a Trailer" test and never went back for a re-test? Seriously...that IS odd, like you said. But I wouldn't lose any sleep over trying to figure out what the fork a P.O. was thinking. That usually leaves you with more questions than answers. If it bugs you, fix it. If, like you indicated, you have yet to use your hitch, then leave it alone and find something worth spending your time on. :2: btw....isn't orange supposed to be for the LEFT stop/signal?
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Lumpy [OP] » September 17th 2014, 12:52am
WHI = Ground
According to my notes -
But, if it was, as you suggest - ONG = L turn/brake, that would make a lot more sense. Maybe they ran out of YEL wire when installing the hitch. I guess I should test and verify it. Maybe someday I'll tow something.
Postby Leeann_93 » September 17th 2014, 1:11am
From the FSM:
• Brown: Rear lamps.
• Yellow: Left stoplamp and turn signal.
• Dark Green: Right stoplamp and turn signal.
• White (Heavy Gage): Ground.
• Light Green: Back-up lamps.
• White (Light Gage): Center High-Mounted Stoplamp.
• Blue: Auxiliary circuit (eight-wire harness only). [brake controller-connect
direct to brake controller]
• Orange: Fused auxiliary (eight-wire harness only) [battery feed-connect to
fuse block]
• Red: 12v power
Postby Astrofarian » September 17th 2014, 3:22am
Leeann_93 wrote:From the FSM:
fuse block]
• Red: 12v power
So now that we know I was wrong about the orange wire, (Thanks, Leann), I have another question. What is the rating on the hitch you have there, Lumpy? Is it the big guy designed for those 70 ft portable motels that I know you love so much? It sounds like the wiring you discovered is one half of the 8-wire plug that Leann referenced. So now, I wonder, where in the hell is the REST of the wiring hiding? Like I said before....more questions than answers, huh? :banana:
Astrofarian
Alias (AKA): M!ke
Postby Lumpy [OP] » September 17th 2014, 6:15am
I believe it is the OEM "Under 2000 lbs curb weight" hitch.
Postby Astrofarian » September 19th 2014, 12:52am
Ok so 2000 lb boat/tent/utility trailer type hitch.....you're probably correct about the ORG wire being a substitute for the YLLW. What kind of connector is on the end of this harness? A flat four-wire would be what I would expect to find.... :confused:
Astrofarian
Alias (AKA): M!ke
Postby Lumpy [OP] » September 19th 2014, 6:55am
Astrofarian wrote:
...What kind of connector is on the end of this harness?
Standard 7 pin round.
It is currently April 15th 2021, 6:36pm
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
