Engine Rad Fan
Engine Rad Fan
Postby imavanner [OP] » October 25th 2014, 10:05pm
The fan under my hood seems to be on and run all the time
i am pretty sure it is on a clutch but always seems to be on when driving
Any input
imavanner
Years of Membership: imavanner has been a member for 6 full yearsimavanner has been a member for 6 full yearsimavanner has been a member for 6 full yearsimavanner has been a member for 6 full yearsimavanner has been a member for 6 full yearsimavanner has been a member for 6 full years
Topics: 9
Alias (AKA): fungalixie
Van Model Year: 1988
Extra Info: SLE 5-Speed Manual
Re: Engine Rad Fan
Postby chevymaher » October 25th 2014, 11:05pm
it does run all the time the clutch just slows it down.
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 3:42am
so when driving and accelerating off the line its normal to always hear a fan over powering the engine noise
imavanner
Topics: 9
Re: Engine Rad Fan
Postby chevymaher » October 30th 2014, 4:05am
It should be like that when it first starts. Untill you get up to speed the first time then it should het quiet. Occasionally you will barely hear it. Sounds like the clutch is wearing out and starting to drag to much.
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 4:14am
ye always seem to hear fan sounds lie its always spinning at max
imavanner
Topics: 9
Re: Engine Rad Fan
Postby chevymaher » October 30th 2014, 4:15am
imavanner wrote:ye always seem to hear fan sounds lie its always spinning at max
It is locked need a new clutch. Or clutch and fan if that is the way they are selling them.
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 4:16am
ok ill replace that is it bad if i drive a bit like that in the mean time
imavanner
Topics: 9
Re: Engine Rad Fan
Postby chevymaher » October 30th 2014, 4:21am
Just wiggle the fan. If it is tight not acting like it coming off. Then it will last forever and not hurt a thing.
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 4:23am
so wiggle the blade
its ok if it runs all the time the van is on kinda sounds like a supercharger like im driving a hover craft or something lol
imavanner
Topics: 9
Re: Engine Rad Fan
Postby RECox286 » October 30th 2014, 4:24am
It robs power from the engine, but the fan is designed to go as fast as the engine will drive it,
and no it won't hurt, it will just cost you slightly more in fuel. Get to it as soon as you can.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 4:25am
ok thanks a lot guys i really value your help its fantastic to have such a cool old van and talk with other owners i love this thing just wanna work out the quirks
imavanner
Topics: 9
Re: Engine Rad Fan
Postby unrreal » October 30th 2014, 9:47pm
If you live in a state that gets snow Then replace the fan clutch otherwise if it is stuck on it will keep cooling the engine preventing it from reaching operating temp and your heat will not work that well.
unrreal
Years of Membership: unrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full years
Topics: 22
Images: 12
Extra Info: 4.3L LS AWD
Re: Engine Rad Fan
Postby imavanner [OP] » October 30th 2014, 10:56pm
Very true i.never thought of that
And we.get snow but I plan to store over winter
imavanner
Topics: 9
It is currently February 25th 2021, 12:09pm
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
