Corroded Wire
Corroded Wire
Postby benoliver [OP] » March 20th 2010, 5:46pm
The red wire on the blower motor is corroded...the high setting on the fan won't work. How do I clean or fix the wire???
benoliver
Years of Membership: benoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full yearsbenoliver has been a member for 10 full years
Alias (AKA): benoliver
Extra Info: 4.3L V6 AWD
  • 12V Accessory wire?
    by gman » December 7th 2020, 7:09am in Electrical
    Last post by gman View the latest post
    December 8th 2020, 8:48am
  • Cut the wrong wire...
    by AstroOafAdventurerAstroOafAdventurer is online! » January 10th 2021, 8:19pm in Electrical
    Last post by AstroOafAdventurerAstroOafAdventurer is online! View the latest post
    January 10th 2021, 10:05pm
    9
    53
    March 1st 2021, 5:48pm
Re: Corroded Wire
Postby astroturf » March 20th 2010, 6:14pm
benoliver wrote:The red wire on the blower motor is corroded...the high setting on the fan won't work. How do I clean or fix the wire???
You could get some electrical contact cleaner. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Re: Corroded Wire
Postby tedanderson » March 20th 2010, 6:22pm
If the high setting does not work, there is probably an issue with the switch. Not the blower itself.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Re: Corroded Wire
Postby benoliver [OP] » March 20th 2010, 6:27pm
Only the 3rd setting on the blower works and it only blows through the defroster...we replaced the vacuum hose that was missing and took the resistor pack off and found the high setting connector corroded.
benoliver
Re: Corroded Wire
Postby rev_les » March 20th 2010, 7:16pm
The red wire being corroded will cause the high setting not to work, it bypasses the resistor pack. As Astroturf suggested, electrical contact cleaner, and scrape or lightly file the male pin, and try to do the same with the female part,I try to get something in there to close it up a bit. You want to see some shiny metal to get good contact.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Re: Corroded Wire
Postby Astroplane » March 21st 2010, 4:05am
benoliver wrote:Only the 3rd setting on the blower works
You'll probably need to replace the blower resistor, but clean the connector and retest it first.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full years
Extra Info: LT RWD
Re: Corroded Wire
Postby benoliver [OP] » March 22nd 2010, 6:51pm
Well we got two of the blower settings to work...Then realized that the fuse for the air conditioner is missing. So we bought a fuse and put it in and the blowers stopped working :screaming: My husband fiddled and fiddled and then gave up, closed the hood, and wham! blowing again :think:
The other thing is, we put the new fuse in and the air conditioner compressor does nothing...doesn't even attempt to start. Any thoughts on that??
benoliver
Re: Corroded Wire
Postby Astroplane » March 23rd 2010, 2:39am
How long have you owned the van? A/C compressor worked prior? Do you have a test light or digital meter for testing?
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
It is currently March 1st 2021, 5:48pm
OldSchoolNoe
Comments: 0
Date: Today
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
