2005 safari loss of power and no roll over please help
Postby Mattcleg [OP] » November 20th 2014, 6:36pm
My 2005 safari is HAUNTING me. It's started with the common no start in wet weather. Eventually even while driving the van began losing power. Then quit. Sit for a few minutes then start and go again. Then it wouldn't start at all. So I have checked the fuel pump pressure it's 60lbs at the rail. I have replaced plugs,wires,ignition modual,map sensor,throttle position sensor,a full distributor, cap and coil. Crank sensor. I finally got frustrated and drilled holes in the catalytic converters to try and see if they were plugged. It would crank over but not start. Plenty of fuel, I have spark and air. I got frustrated and cut the exhaust where the Y pipe meets. Still no go. I took it tithe dealer and they replaced the pins in the ignition and cut me a new key. The van fired right up I drove it home twenty minutes loud as heck and not running perfect but I made it home. So I repaired the exhaust and I noticed it would hesitate more and more before allowing the starter to engage but no clicking. I drove it and guess what same loss of power I had right from the start. Then the van quit. Now I have that same problem and now it has lots of battery power but won't roll over. When I turn the key to the on position the security light flashes then goes out. The battery light stays on as well as the engine light but that has always been on. I have checked both fuse boxes all good. I have checked and cleaned an re connected all my grounds and wires. I don't know where to go from here frustrated. Please help. Thanks .
Mattcleg
Years of Membership: Mattcleg has been a member for 6 full yearsMattcleg has been a member for 6 full yearsMattcleg has been a member for 6 full yearsMattcleg has been a member for 6 full yearsMattcleg has been a member for 6 full yearsMattcleg has been a member for 6 full years
Extra Info: 4.3 v6 red
Re: 2005 safari loss of power and no roll over please help
Postby The Drummer » November 27th 2014, 11:08pm
bump
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 49
Extra Info: SLT 4.3 AWD
Postby redfury » November 27th 2014, 11:45pm
Could be a problem with passlock with the new ignition and key. I'd look into doing a passlock relearn. It's lengthy, but that's so someone can't just cut a key and run away with your van. I'd start there first. Loss of power, if it's a plugged converter is easy to test for. Get a vacuum gauge and run the engine to 2500 rpm. If you start seeing the vacuum drop, then you have a restricted exhaust.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
It is currently April 17th 2021, 4:07am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
Users browsing this forum: No registered users and 17 guests
