any body had any experience with these
Postby wizical [OP] » April 9th 2010, 1:31am
external pump
http://www.jegs.com/i/MSD-Ignition/121/ ... tId=752083
High Pressure Electric Fuel Pump
MSD High Pressure Electric Fuel PumpMultiport EFI systems require a stable fuel supply to maintain best performance throughout the engine's rpm range. This high pressure and high flow Fuel Pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The pump mounts in-line (out of the fuel tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8" with a 5/16" outlet. The wire terminals feature brass studs for secure connections. Made in the USA, the pump is ideal for use as a "booster" for nitrous oxide applications, or as a stand alone pump for multiport EFI systems on engines up to approximately 500 HP. Capable of 43 gph at 40 psi.
Approximate flow is 43 gph (282 lb/hr) gasoline (specific gravity 0.788) @40 psi and 12 volts/5.4 amps. Has 3/8-in. hose nipple Inlet, 5/16-in. hose nipple Outlet. Includes 2 cushioned mounting clamps and 4 mounting bolts.
wizical
Firing on 8 Cylinders (L1)
Years of Membership: wizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full yearswizical has been a member for 11 full years
Topics: 18
Alias (AKA): viatronic discombobulator
Extra Info: peice O krap
  • Boy, these are expensive!!!!!
    by xit » December 22nd 2020, 7:12pm in Electrical
    December 25th 2020, 2:23am
  • Electrical issues - could these be related
    by hiteq55 » January 21st 2021, 3:13am in Electrical
    Last post by hiteq55 View the latest post
    January 22nd 2021, 1:01am
    March 1st 2021, 5:48pm
Re: any body had any experience with these
Postby Jasen » April 9th 2010, 1:37am
Not sure what the gph is for the 4.3 but if it's 43 gph I don't think that pump will work seeing we need around 60 psi
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby wizical [OP] » April 9th 2010, 1:43am
how about this one then !
http://www.summitracing.com/parts/SUM-G3138/
Free Flow Rate 43 gph
Maximum Pressure (psi) 85 psi
Inlet Size 5/16 in.
Inlet Quantity Single
Inlet Attachment Hose barb
Outlet Size 5/16 in.
Outlet Quantity Single
Outlet Attachment Hose barb
Quantity Sold individually.
Notes Fuel pump overall length is 7.250 and diameter is 1.812.
wizical
Topics: 18
Postby astro355 » April 9th 2010, 5:19am
They are noisy pumps so be ready for that. And with the summit pump, you will probably need a different fuel pressure regulator.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby wizical [OP] » April 9th 2010, 5:25am
sound wont be a prob
wizical
Topics: 18
Postby Jasen » April 10th 2010, 1:08am
wizical wrote:sound wont be a prob
Nothin a subwoofer or two won't take care of.
200k
Ultra gauge
Topics: 260
Images: 101
Postby wizical [OP] » April 10th 2010, 3:36pm
lol
or gasbag in pas seat!
wizical
Topics: 18
Postby wizical [OP] » April 10th 2010, 3:41pm
well just ordered this one
http://cgi.ebay.com/ebaymotors/NEW-FUEL ... ccessories
will see how it goes
cause the price is right
wizical
Topics: 18
Postby astroturf » April 12th 2010, 1:42pm
wizical wrote:well just ordered this one
Hey Wiz, Is that you of those MADE IN CHINA pumps? Just curious, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby wizical [OP] » April 12th 2010, 10:09pm
i dont know jim
all i know is my s10's been sitting in my yard way too long
and beats the hell out of $595+taxes cdn
wizical
Topics: 18
Postby astroturf » April 12th 2010, 10:17pm
wizical wrote:i dont know jim
You ain't lyin. That's a boat load of cash. Is that what a Delphi pump would cost you? I didn't know. I'm sorry. Jim
astroturf
Topics: 112
Postby wizical [OP] » April 12th 2010, 11:06pm
yup from lordco or napa
no used in the area closest was victoria for $350 + Taxes + shipping
hell when i used to have my 1988 gmc 1 ton the sender unit was gone and they wanted $500 (pump not in tank)
they all said nothing we can do
so i did some searchin and came up with an accel sender for $50 cdn ( made lordco order it )
took out old sender made a pattern cut plate and then another for the new sender and in stalled
wroked like a dream after a little adjusting of the float
wizical
Topics: 18
It is currently March 1st 2021, 5:48pm
OldSchoolNoe
Comments: 0
Date: Today
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
