Weird Issue
Weird Issue
Postby Yaycandy [OP] » January 11th 2015, 9:24pm
Im having an issue with my 94 awd W. Now im getting less mileage because of it. It throws a check engine code while idleing. Randomly comes on for like 10 seconds and goes away for a while. At random idle times. I checked code with a paperclip and its code 35 for iac. But know how when you have the heater on. It will kick on the ac for like a few seconds and then it shuts off. Continuously. Now it has been like 4 degrees in my area of poconos pa. It has always done that where the ac kicks on for a few seconds. Now it dosnt kick on at all. Idk if that is part of the iac code or not. I havent done anything yet to attempt to fix it. I may just clean the iac. Or unplug the compressor. Anyone with expirence of this. Is the ac bad. Or is it no pressure in ac because its been dead cold for weeks. I only notice problem when its very cold.
Yaycandy
Years of Membership: Yaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full yearsYaycandy has been a member for 8 full years
Topics: 34
Extra Info: AWD EXT CL 206k
  • Weird Electrical Quirks
    by rstro » June 14th 2020, 11:41pm in Electrical
    Last post by rstro View the latest post
    June 15th 2020, 12:48am
  • turn signal issue.
    by 1995Astrodizzle » July 26th 2020, 12:45pm in Electrical
    Last post by 1995Astrodizzle View the latest post
    July 26th 2020, 2:02pm
    October 25th 2020, 5:42am
Re: Weird Issue
Postby chevy57bert » January 11th 2015, 9:35pm
35= Idle speed error.. if your AC steps in.. your idle would be to low?
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Re: Weird Issue
Postby Yaycandy [OP] » January 11th 2015, 9:38pm
The ac always stepped in only when the heater was on a certain selection like htr or window blower. It dont kick on no more when i put it to those selections or any selections. Idk if its because the iac. Or if its a dum computer that on thing goes bad and computer no comprendo and acts dum
Yaycandy
Topics: 34
Re: Weird Issue
Postby kennysmoke » January 11th 2015, 10:52pm
The AC kicks on in the defrost settings ... last two selections all the way right...
"Live Free Or Die" Image
kennysmoke
Blue Status (L2)
Blue Status (L2)
Topics: 68
Images: 7
Alias (AKA): kennysmoke
Extra Info: AWD Tow Pakage
Re: Weird Issue
Postby chevymaher » January 12th 2015, 12:15am
kennysmoke wrote:The AC kicks on in the defrost settings ... last two selections all the way right...
yes anytime the windshield is involved.
Re: Weird Issue
Postby Yaycandy [OP] » January 12th 2015, 5:56am
But it throws code for 35 same time that stopped working. Ill unplug ac and clean intake and iac and see ifin its fixed. I have kustum k&n cone intake. Made from pcv. Thats been on there for like 7 years without being cleaned. Ill clean the filter. Its all clogged probaby. And intake could take some squirtins and ill have fun making smoke with crc intake cleaner
Yaycandy
Topics: 34
Re: Weird Issue
Postby Yaycandy [OP] » January 12th 2015, 5:33pm
Well i took off air box and cleaned the filter. Cleaned the throttle body with crc. Unplugged the ac. Still throws code. I guess it is the iac. The bracket is in the way. Has cruisecontrol and all on it. Anyone tell what bolts need removed from it and what dont need removed from it.
Yaycandy
Topics: 34
Re: Weird Issue
Postby Yaycandy [OP] » January 12th 2015, 5:37pm
Still on
Yaycandy
Topics: 34
It is currently October 25th 2020, 5:42am
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
