Instrument cluster lights gone only!
Postby mikegenin [OP] » April 21st 2010, 6:03pm
Hi guys,
New here, but have always used mymonte.com with a lot of luck when it comes to my other car.
Got a 95 Safari, I had replaced most of the bulbs on my instrument cluster a while ago since a few burnt out. Months went by, now none of them work at all. The lights for my hvac / radio / lifgate etc.. buttons all work fine tho! and the dimmer controls them just fine! Searched around and see a lot of you had issues with dimmer switches and the headlamp switches... could this still be an issue?
Checked all fuses, bulbs, took the instrument cluster out again, no luck yet.
Any help would be great.
Mike.
mikegenin
Years of Membership: mikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full yearsmikegenin has been a member for 11 full years
  • CEL not working correctly, Instrument panel?
    by Themistocles » November 28th 2020, 5:40pm in Electrical
    December 4th 2020, 1:25pm
  • Instrument pinout 97 Astro
    by Delshan » December 6th 2020, 12:43pm in Electrical
    Last post by Delshan View the latest post
    December 7th 2020, 1:07pm
    88
    April 21st 2021, 12:36am
Re: Instrument cluster lights gone only!
Postby LEVE » April 21st 2010, 9:01pm
If the other lamps are operated by the switch, the switch is good. I'd be looking at the gray wire that feeds voltage to the instrument panel. If there's voltage there, then I'd look at the copper patterns on the instrument panel circuit board. It cold be corrosion, or a cold solder joint.
LEVE
Years of Membership: LEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Jasen » April 22nd 2010, 3:39am
Welcome to A/s
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby astroturf » April 22nd 2010, 3:46am
Jasen wrote:Welcome to A/s
X2
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby mikegenin [OP] » April 26th 2010, 6:41pm
No luck with checking the switches,
I changed out the entire instrument cluster and it fixed the problem right up!
Thanks guys.
mikegenin
Postby astroturf » April 26th 2010, 10:27pm
Do you know what caused the problem on the old one? And, I'm glad you got it fixed. Jim
astroturf
Topics: 112
Postby Mr_Bowtie » April 27th 2010, 6:46am
Welcome! :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
It is currently April 21st 2021, 12:36am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
Users browsing this forum: SurfinSafari97 and 12 guests
