Any way to check an alternator belt?
Postby Chrisw443 [OP] » February 9th 2015, 9:56am
I took my new van into the shop for an oil change, (I know I am a noob) But the mechanic said because my belt was a little squeaky i should change it? I don't think i need to for quite a while, but I am all worried now. Course I can't hear the squeak. Anyway, is there a guideline to which belt on a 1995 safari is the alternator belt, and a good way to check it?
Van runs perfect so far.
Chrisw443
Years of Membership: Chrisw443 has been a member for 5 full yearsChrisw443 has been a member for 5 full yearsChrisw443 has been a member for 5 full yearsChrisw443 has been a member for 5 full yearsChrisw443 has been a member for 5 full years
Alias (AKA): none
Extra Info: V6 RWD
Re: Any way to check an alternator belt?
Postby chevymaher » February 9th 2015, 1:13pm
On the grooved side do you see small cracks. No then it fine. Yes then that the guideline to change it. But it would last years still. Just so you know it isnt a panic situation even then.
Postby 1998kingbong » February 9th 2015, 1:46pm
Sounds like he is trying to drum up work. If the price sounds fair have them do it. If you do not know the history of your van, somethings are good to just replace.
1998kingbong
Years of Membership: 1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years
Topics: 19
Extra Info: awd 165000
Postby Lumpy » February 9th 2015, 2:29pm
There's only one belt on your engine. It snakes around all the pulleys on your engine (called a serpentine belt for that reason).
I suggest - Go to any online auto parts store and look up your van year/make/model and see what a new serpentine belt costs. Then compare that to what the oil change guy is asking for the belt + labor. If the difference seems acceptable to you, then you can make an informed choice.
ALWAYS keep the old belt in case of an emergency.
Replacing a serpentine belt is just slightly more involved than checking your oil or coolant level. It's less work/time/tools required than changing a flat tire. One wrench, 5 minutes and it's done. Look for a sticker in your eng compartment that shows the routing of the belt - over this one, under that one etc.
Postby Coaster » February 9th 2015, 2:34pm
if you own a 95 without AC you can expect an afternoon of searching for the right belt, and the third or fourth one you pull out of the box may be the right one. trust me the parts guy will be a frustrated as you
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby Lumpy » February 9th 2015, 2:41pm
Coaster wrote:if you own a 95 without AC you can expect an afternoon of searching for the right belt, and the third or fourth one you pull out of the box may be the right one. trust me the parts guy will be a frustrated as you
Take the belt to NAPA. They'll match it either with the numbers on the belt or by physically measuring it or by the lookup tables - or all three.
NAPA or Gates are the only belts that I'll buy.
Postby RECox286 » February 9th 2015, 8:12pm
My LAPS carries Dayco brand, so it is the brand of choice for my trucks for the past 30 years.
They have given me good service...as good as OEM, so I can't complain. They run on my air
compressors, table saws, cars, trucks, and anything else that takes a belt.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Chrisw443 [OP] » February 9th 2015, 9:44pm
Well thanks for all the responses, I'll double check the belt today before I leave, however, I looked at the belts last night, they look intact to me. So I think he was just trying to get money outta me.
Chrisw443
Alias (AKA): none
Extra Info: V6 RWD
Postby Lumpy » February 10th 2015, 12:16am
Chrisw443 wrote:
... I looked at the belts last night...
BELT (singular). There's only one.
Postby RECox286 » February 10th 2015, 12:24am
Speaking of belts...just one more for the road, please.
Unkle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby Leeann_93 » February 10th 2015, 12:40am
Chrisw443 wrote:Well thanks for all the responses, I'll double check the belt today before I leave, however, I looked at the belts last night, they look intact to me. So I think he was just trying to get money outta me.
Just because it (seriously: one belt, so it) 'looks intact' doesn't mean it's any good. They stretch, they crack on the underside....
Replace the belt, replace the belt tensioner. It's 15 minutes of your time and you'll know you're good for the next 40,000 miles plus.
It is currently January 22nd 2021, 5:06pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
Users browsing this forum: lilsmokielilsmokie is online! and 14 guests
