by JayDubya [OP] » May 5th 2010, 10:55pm
by LEVE » May 5th 2010, 11:12pm
by timelessbeing » May 5th 2010, 11:12pm
by webcat » May 6th 2010, 12:11am
by JaxSPL » May 6th 2010, 12:46am
by timelessbeing » May 6th 2010, 1:09am
JaxSPL wrote:How big of wire you talking about? Where is your amplifier going to be located?
I ran my 4/0 under the van. Right down the frame and tried to tuck it away as much as possible form any moving parts in the engine area. It enters the van right by the driver side rear tire well.
Quick, simple, and don't have to worry about drilling into anything except the back floorboard.
by Jasen » May 6th 2010, 2:07am
by JayDubya [OP] » May 6th 2010, 3:13am
by Jasen » May 6th 2010, 3:32am
by JayDubya [OP] » May 6th 2010, 3:51am
by timelessbeing » May 6th 2010, 4:10pm
by LEVE » May 6th 2010, 4:16pm
I agree. May I suggest a cure? One thing you can do is use 1/2" ABS or PVC pipe as a conduit, as well as a cover for the wiring. It's easily worked with as well as very tough stuff. Just cut, fit, run the wire and then strap it to the underside of the body and it's going to keep the enclosed wiring free from nicks/cuts, dirt and debris. It's a whole lot better than plastic spiral wrap.Jasen's got the right idea there in the photo, except it's still too exposed for my liking.
To counter this problem... fuse the line at the power source and the problem goes away.One stray rock and you have an electrical fire on your hands.
by Jasen » May 7th 2010, 3:22am
by JaxSPL » May 7th 2010, 6:04am
by JayDubya [OP] » May 7th 2010, 7:01am
JaxSPL wrote: . I can't find a holder big enough for my wire so I haven't installed a fuse. Plus, I'd need to get a fuse of about 380 to 400amps.
by JaxSPL » May 7th 2010, 3:30pm
by 94 Van Guy » May 7th 2010, 3:57pm
It is currently April 15th 2021, 6:37pm
Electrical Forum |
Previous topic Next topic |
Sponsors |
