no acc mode
no acc mode
Postby highmilegmc [OP] » February 20th 2015, 10:12pm
My ignition switch won't go into acc it acts
Like it don't have one at all it turns to on/start/run but
When I goto acc it stops at the off position anybody else
Have this problem?
2000 gmc safari cargo, future 350 4bbl
All wheel disk,
Seek ye first the kingdom of heaven and all these
Things will be granted unto you.
Van on :)
highmilegmc
Years of Membership: highmilegmc has been a member for 6 full yearshighmilegmc has been a member for 6 full yearshighmilegmc has been a member for 6 full yearshighmilegmc has been a member for 6 full yearshighmilegmc has been a member for 6 full yearshighmilegmc has been a member for 6 full years
Topics: 34
Images: 44
Alias (AKA): spark plug
Extra Info: 2wd cargo
  • no alt charge and engine idles only
    by Astro plain jane » August 31st 2020, 9:15pm in Electrical
    Last post by Astro plain jane View the latest post
  • No power
    by equitube » September 13th 2020, 4:55am in Electrical
    September 17th 2020, 5:40am
    58
    March 1st 2021, 8:35am
Re: no acc mode
Postby chevymaher » February 20th 2015, 10:14pm
highmilegmc wrote:My ignition switch won't go into acc it acts
Have this problem?
No me. I can switch to acc so fast the DVD player don't restart.
Re: no acc mode
Postby highmilegmc [OP] » February 20th 2015, 10:33pm
Randy I don't understand
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby chevymaher » February 20th 2015, 10:47pm
highmilegmc wrote:Randy I don't understand
You ask if anyone had trouble getting the key to got to acc position.
My DVD player if it looses power has to reboot.
I was clowning I can go from running to in the acc position so fast the DVD stays on.
Mine you have to have it in park and push the key inward to get it to turn. Try holding the shifter up while you try to turn it. Maybe a linkage issue. It is staying locked out.
Re: no acc mode
Postby highmilegmc [OP] » February 20th 2015, 11:13pm
Il try that
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby highmilegmc [OP] » February 20th 2015, 11:31pm
Shifter don't have a impact but kicking
It back and forth hard n fast n got acc twice any ideas
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby chevymaher » February 20th 2015, 11:38pm
Hose it down up in the shifter and anywhere you see a opening with WD 40. Wipe it down and let it soak a day or so. May be dried grease in there holding the thing in place.
Re: no acc mode
Postby highmilegmc [OP] » February 20th 2015, 11:40pm
Wd40 wont hurt electronics?
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby chevymaher » February 21st 2015, 12:30am
highmilegmc wrote:Wd40 wont hurt electronics?
Nope it is silicon based. Electronics love it.
Re: no acc mode
Postby highmilegmc [OP] » February 21st 2015, 2:49am
Where should I spray into
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby Lumpy » February 21st 2015, 2:54am
For a long time I thought mine didn't even have an ACC position. Then these guys gave me the advice Maher suggests. Wiggle, push, pull, lube etc...now I've got ACC.
Re: no acc mode
Postby highmilegmc [OP] » February 21st 2015, 3:10am
Lump where did u spray ur wd40 at
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby Lumpy » February 21st 2015, 4:12am
You can't spray it in the wrong place. Put the key part way in, stick the WD40 straw in with it. Spray a bit. Here and there, wherever.
Mostly it was realizing that there was an ACC position. Once I felt how to get it there, it comes naturally now. Like riding a ballet dancer.
Re: no acc mode
Postby highmilegmc [OP] » February 21st 2015, 4:20am
So there is a trick accompanied by a lack of
Lubercant?
All wheel disk,
Van on :)
highmilegmc
Topics: 34
Images: 44
Re: no acc mode
Postby chevymaher » February 21st 2015, 5:05am
highmilegmc wrote:So there is a trick accompanied by a lack of
Lubercant?
Push the key/tumbler in as you turn it back.
Re: no acc mode
Postby zzimmer3 » February 21st 2015, 5:14am
I think that's hilarious! But, if I'm not mistaken, aren't there male dancers, too?
1994 2wd, 1998 2wd, 2000 awd, 2001 awd
zzimmer3
Years of Membership: zzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full yearszzimmer3 has been a member for 7 full years
Topics: 68
Images: 50
Alias (AKA): teddybear
Extra Info: LT AWD
Re: no acc mode
Postby Astrofarian » February 21st 2015, 5:50am
GM lock cylinders are factory assembled using a silicon-based lube. WD40 is mostly solvent. It WILL get your cylinder freed up but you'll be wiping goopy-spooge off of your key for the next month or so before you put it in your pocket. A little goes a long way here, guys. Use the straw and try to direct it UPWARD because that's where the individual tumblers are. You can always spray more if you need to but it's a smelly, messy business to clean up sometimes.
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: no acc mode
Postby tedanderson » February 21st 2015, 7:03am
Whenever mine would stick, I would just give it some "wrist action" where I quickly spun it back without a whole lot of effort. I eventually learned how to get the action just right to where the continuous movement kept it going. It was more finesse than it was forceful.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Re: no acc mode
Postby Lumpy » February 21st 2015, 7:10am
tedanderson wrote:Whenever mine would stick, I would just give it some "wrist action" where I quickly spun it back without a whole lot of effort. I eventually learned how to get the action just right to where the continuous movement kept it going. It was more finesse than it was forceful.
^^^ This, more than any worry about lubricant.
It is currently March 1st 2021, 8:35am
OldSchoolNoe
Comments: 0
Date: Today
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
cron
