obd II pinout
obd II pinout
Postby $uperJoe [OP] » May 24th 2010, 8:20pm
this is what i found at ls1 tech and was wondering if this is correct for 1996 sfi 5.7L as well.
also if 4 and 5 are grounds are they from different circuits? one is black and one is black with white
there are 4 other wires in mine that are not pictured
8.....black/white...?
9.....tan.............airbag
12....tan/white.....?
14....green..........stereo
what are these other 4 wires for and do i need them?
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Re: obd II pinout
Postby chevy57bert » May 24th 2010, 8:55pm
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Re: obd II pinout
Postby $uperJoe [OP] » May 24th 2010, 8:57pm
im confused as to what those values are bert. do you have any more info on them?
$uperJoe
Topics: 59
Re: obd II pinout
Postby chevy57bert » May 24th 2010, 9:01pm
$uperJoe wrote:im confused as to what those values are bert. do you have any more info on them?
Life is Confusing :rofl:
I try to get info about those colors..
in this PDF there are 7 wires standard. # 2 4 5 7 10 15 16
obd_02 wiring.pdf
(30.25 KiB) Downloaded 376 times
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Re: obd II pinout
Postby chevy57bert » May 24th 2010, 10:07pm
97 TJ with a 2003 5.3L out of a full size Chevy truck.
Pin 3- Purple
Pin 4- Black w/ Blue stripe
Pin 5- Black w/ Tan stripe
Pin 6- Green
Pin 7- Pink
Pin 10- White w/ Black stripe
Pin 16- Pink w/ While stripe
The industry standard 7 pins are 2,4,5,7,10 and 16.
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Re: obd II pinout
Postby webcat » May 24th 2010, 11:00pm
Just last night i was looking for the same thing but did'nt find anything.
I have a FSM coming in the mail , when it gets here i'll let you know what i find out.
I was also wondering how this ALDL ties in to the rest of the schematic , i'm making a custom schematic and the only thing i cant figure out is how the ALDL ties in and the single black wire goes where on the transmission?
After i get this schematic done i'll be able to make really cheap and simple engine wiring harnesses.
Sorry for taking this off topic but thought you'd be interested.
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Re: obd II pinout
Postby chevy57bert » May 25th 2010, 12:16am
Just thinking WebCat..
You have a black wire (Black is ground wire)
Your transmission wiring is done. maybe this is the ground wire that goes to the trans ????
( I not in transmissions )
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Re: obd II pinout
Postby $uperJoe [OP] » May 25th 2010, 12:21am
i dont think its that far off topic. as i can tell from my notes i have and the wires i cut today the black solid on 4 is a chassis ground and black and white on 5 the signal ground is the one that ties into trans on the plug by the shift lever. its wire D in plug 1(top). it is also the wire that connects in the front right side of the engine. i dont know why they are different but i will hook them both up respectively. maybe one is tied to those grounds to eliminate electrical noise
$uperJoe
Topics: 59
Re: obd II pinout
Postby webcat » May 25th 2010, 12:23am
chevy57bert wrote:Just thinking WebCat..
You would'nt need a wire though , if the transmission needed grounded you would ground to chassis.
webcat
Topics: 253
Re: obd II pinout
Postby chevy57bert » May 25th 2010, 12:26am
Found this.. any use Joe?
vortecv8harness.pdf
(429.35 KiB) Downloaded 166 times
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Re: obd II pinout
Postby $uperJoe [OP] » May 25th 2010, 12:26am
no its to send a signal to the digital display dash for gear indicator. not to ground the trans
$uperJoe
Topics: 59
Re: obd II pinout
Postby webcat » May 25th 2010, 4:02am
webcat wrote:I have a FSM coming in the mail , when it gets here i'll let you know what i find out.
Just found out they shipped it today and will arrive in 2 thru 9 days , if its got the OBD ll pinout i'll post it .
webcat
Topics: 253
Re: obd II pinout
Postby Astroplane » May 25th 2010, 8:14am
"there are 4 other wires in mine that are not pictured
14....green..........stereo"
I have no idea if any of this applies to your situation. Just tossing ideas your way.
The '97 M/L says:
8.....Keyless Entry program enable signal
9.....Serial Data (test with a DMM, should see fluctuating values in the mV range)
12....ABS diagnostic
As far as the two grounds, one is true chassis ground straight from the battery and the other is a 'diagnostic' ground, AKA 'floating' ground, and more accurately a 'resisted' ground. The VCM needs to be able to differentiate between the two to know if there is a problem.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Re: obd II pinout
Postby Astroplane » May 25th 2010, 8:22am
Also, the first pinout that chevy57bert posted is for a Controller Area Network vehicle.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Re: obd II pinout
Postby $uperJoe [OP] » May 25th 2010, 3:40pm
no thats good stuff, thanks astroplane. since i eliminated the abs completely that makes sense that i couldnt find where the "12" goes. i forgot that it would have a wire for it.i will eliminate that one.
now mine is set up purple on 2 and that should b the pcm serial data.
is 9 another connection for the same thing?
why would one go to the stereo?
$uperJoe
Topics: 59
Re: obd II pinout
Postby Astroplane » May 26th 2010, 7:47am
I had measured all the pins on my DLC a couple of weeks ago in an attempt to update my FSM misprint thread. I just uploaded a video that I have no idea how to link to this thread. I'm not even sure where it ended up. It shows what might be seen on a DMM while probing pins 2 or 9 to ground with key ON. Both pins show similar results when tested. If the meter was on mV range I'm sure it would have been easier to see. All of it measured less than 1V.
Joking begins here:
I wish I could help more with the stereo pin, but all I can do is assume it is used so the scanner can download bootleg music over the onstar system. End of joking.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Re: obd II pinout
Postby rev_les » May 26th 2010, 5:57pm
Astroplane wrote:I had measured all the pins on my DLC a couple of weeks ago in an attempt to update my FSM misprint thread. I just uploaded a video that I have no idea how to link to this thread. I'm not even sure where it ended up. It shows what might be seen on a DMM while probing pins 2 or 9 to ground with key ON. Both pins show similar results when tested. If the meter was on mV range I'm sure it would have been easier to see. All of it measured less than 1V.
Joking begins here:
*You'd need to upload limewire ,etc to your VCIM* :mrgreen: (joking as well)
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Re: obd II pinout
Postby Matrixx » May 26th 2010, 6:44pm
Hi $uperJoe
If your referring to OBD II, then Slot 9 (Tan wire) goes to the SDM (Sensing Diagnostic Module) located under the drivers seat if I'm reading your post correctly. It should enter that SDM plug-in at Slot-5.
Just a heads up here with Slot 2 (Purple wire) if you not alreay aware of it is, somewhere along that line to the PCM, it branches off to the BPMV as well. It stays the same color though (Purple).
Hope this helps.:)
Matrixx
Re: obd II pinout
Postby $uperJoe [OP] » May 26th 2010, 8:15pm
matrixx i didnt know that, well either of those things.
first i guess what is bpmv?
second what does sdm do and do i need it to run?
$uperJoe
Topics: 59
Re: obd II pinout
Postby $uperJoe [OP] » May 26th 2010, 9:14pm
found it. brake pressure modulator valve. i dont have that any more. i took all the antilock componets out including that. i used that spot to mount my pcm.
as for the sdm i think it is only pertinent to crash data from airbag deployment. am i wrong in this?
still do i need these things or can i eliminate those wires completely??
$uperJoe
Topics: 59
It is currently November 27th 2020, 6:56am
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
