Loss of Power when too much pedal
Postby Mike H [OP] » April 12th 2015, 5:46pm
Hey all, I've been in love with this site ever since I got my 97 LT AWD about 2 years ago. I finally officially joined today!
Anyway...I have a small vac leak code. I can accelerate slowly and it seems fine, but when I press the pedal down more than half way it looses power. It also started giving me trouble starting in the rain. Changed cap and rotor and everything except the check engine light was fixed. It starts great, drives great, has power all the way through pedal...2 days later I finished the tune up with plugs and wires. Immediately back to the loss of power issue. Plugs are gaped to .06, nothing visually out of the ordinary. I'm going to check all vacuum lines and change fuel filter today.
Any ideas in the mean time?
oh yea...222k miles and this is the first serious problem so far!
Mike H
Years of Membership: Mike H has been a member for 6 full yearsMike H has been a member for 6 full yearsMike H has been a member for 6 full yearsMike H has been a member for 6 full yearsMike H has been a member for 6 full yearsMike H has been a member for 6 full years
Alias (AKA): thumbs1821
Extra Info: LT 4.3L V6 AWD
Re: Loss of Power when too much pedal
Postby TaxiVan » April 12th 2015, 8:55pm
My 98 had similar issues in the rain that drove me crazy for a year or two, turned out I had problems in the O2 sensor wiring... Would also do a leakdown test to make sure your injection unit isn't flooding the intake (another problem I had). :2:
Might check for carbon tracking on the coil, sometimes voltage can arc there as well. Maybe EGR needs to be cleaned?
'98 GMC Safari SLT AWD - BROKEN
Just published my first novel on Kindle - http://www.amazon.com/Lucky-Number-Thirteen-Colyer-Jameson-ebook/dp/B00OY0UCAU
Also a singer/rapper/songwriter - https://www.facebook.com/pages/Allergic-To-Air/209678145727598
TaxiVan
Firing on 7 Cylinders (L1)
Years of Membership: TaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full yearsTaxiVan has been a member for 10 full years
Topics: 72
Alias (AKA): James
Extra Info: SLT AWD 3.73 G80
Postby Mike H [OP] » April 12th 2015, 11:16pm
Well, I think I figured it out...Codes today were - Low MAF - Small evap leak - catalytic converter o2
First : Vacuum line leading down to the canister behind the passenger front wheel was literally crumbling in my hand. - Replaced
Second : Cleaned MAF sensor and replaced air filter. (it was pretty dirty)
Third : Cleaned PCV with carb/choke cleaner
Check engine light is now off, and when I pulled on to the entrance ramp to the highway on my test drive it downshifted and threw me back into my seat! (compared to how it's been driving). Smooth idle, smooth revs, and...the selector switch for the heat changes zones again.
Mike H
It is currently April 18th 2021, 4:13am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
