by Astrosport [OP] » April 26th 2015, 3:34am
by Lumpy » April 26th 2015, 3:38am
by 97cargocrawler » April 26th 2015, 4:14am
by Astrosport [OP] » April 26th 2015, 4:59am
by Lumpy » April 26th 2015, 5:57am
by 97cargocrawler » April 26th 2015, 7:02am
by Sailing_Faith » April 26th 2015, 7:17am
by Lumpy » April 26th 2015, 7:41am
by 97cargocrawler » April 26th 2015, 8:03am
Lumpy wrote:I'm pretty sure a higher amp capacity alternator wouldn't be a factor in charging. Your typical solar array is capable of something like 17 amps. Typical tricle charger is ~2A. Typical "fast charge" on a battery charger is 25A. All are quite a bit less than an automobile alternator.
If you squeeze scorpion blood into the battery cells, they won't recharge any faster. But I'll buy you a burrito.
by Lumpy » April 26th 2015, 8:42am
97cargocrawler wrote:
If you're pushing the limits of the alternator running stock onboard gear and then add the huge initial draw of some highly discharged batteries....you don't think that could max out the alternators current capacity?...
by chevymaher
» April 26th 2015, 1:00pm
by Astrosport [OP] » April 26th 2015, 3:25pm
by Astrosport [OP] » April 26th 2015, 3:55pm
Lumpy wrote:Perhaps let's define what you mean by "charging my batteries". Are they dead? Are they in use normally and just discharged a bit? Are they in use and discharged a LOT etc.
I guess I pictured you trying to charge discharged batteries with your parked, running van.
by Lumpy » April 26th 2015, 3:56pm
by JaxSPL » April 26th 2015, 5:10pm
by Meterpig » April 26th 2015, 5:39pm
by Astrosport [OP] » April 26th 2015, 6:43pm
Meterpig wrote:The charging circuit from the alternator, at least on my van, has one customer and that is the battery. All electronics run off the battery full time. Of course the battery can fail to hold a charge, but still allow voltage to pass through. When this happens, it can look like dimming headlights at idle.
You can charge a battery faster with higher amperage which can look like higher voltage on the voltmeter. I have a little powerwheels battery that can be charged at a faster rate. I usually leave it on at 2 amps or the battery gets pretty warm, boils..etc. Remember the 80/20 rule. A battery can in theory accept higher amperage up to 80%. The last 20% is when it needs a more optimal charging amperage. I don't know if our vans do this or not. I am guessing not given that the battery is a technology from 1880.
To the OP's question, you need more amperage which will translate into higher voltage on the meter in theory. If you alternator is producing a true 100-120 amps at 1000rpms, that should be more than enough to charge a few batteries from a 50% charge. The real issue is how you have the wired together. Are they isolated? Is the current being sent only one direction under charge? There are a bunch of write ups out there how to do this. The bottom line is...you need a larger alternator. There is no free lunch. It's either a $600 alternator or a $900 generator.
On a side note, my experience is a factory AC delco will produce higher voltage all the time. My aftermarket 120amp alternator from the parts store fluctuated much better with load. After a long drive with no load, the voltage would drop to an even 13.5. The Declo would run 14.2 no matter what. Which..I think...fried my Interstate and costco battery nicely. Warranties are great.
by Lumpy » April 26th 2015, 8:06pm
Meterpig wrote:The charging circuit from the alternator, at least on my van, has one customer and that is the battery. All electronics run off the battery full time...
...To the OP's question, you need more amperage which will translate into higher voltage on the meter in theory. If you alternator is producing a true 100-120 amps at 1000rpms, that should be more than enough to charge a few batteries from a 50% charge...
by Meterpig » April 26th 2015, 8:44pm
by Meterpig » April 26th 2015, 8:48pm
Astrosport wrote:Meterpig wrote:The charging circuit from the alternator, at least on my van, has one customer and that is the battery. All electronics run off the battery full time. Of course the battery can fail to hold a charge, but still allow voltage to pass through. When this happens, it can look like dimming headlights at idle.
You contradicted yourself , You typed that my stock alternator would be more than enough to charge a few batteries from 50% but then you typed I need a bigger alternator .
I'm glad you brought up your Delco cooking the batterys because it was constantly running 14.2 volts , because it made me realize I left something out of my first post .
I typed that a solar guy told me that I needed 14.8 volts to get the batterys to charge good , I left out that the charge controller would only apply the 14.8 volts for a certain amount of time and then back off.
If the charge controller wasn't on this guys solar system he probably would have cooked his batteries too.
It is currently February 26th 2021, 7:25pm
Electrical Forum |
Previous topic Next topic |
Sponsors |
Users browsing this forum: Google [Bot] and 11 guests
