Removed Lower Shroud Can not get it back it
Postby selcooper [OP] » June 1st 2015, 1:34am
Okay so i had to do an Alternator and belt fix on my 2004 GMC Safari AWD
I did the repair ok and with the bosses opps I mean the wife's help was able to get the belt in place.
But when i went to replace the lower shroud I could not get it to seat back into its original position. to make matters worse I snapped one of the clips down at the base where the unit should clip into.
So I guess i am definitely calling for help as to what to do to get this piece back into the position that it needs to be in.
PS do not tell my wife I am asking for help it will ruin my rep
selcooper
Years of Membership: selcooper has been a member for 5 full yearsselcooper has been a member for 5 full yearsselcooper has been a member for 5 full yearsselcooper has been a member for 5 full yearsselcooper has been a member for 5 full years
Extra Info: SLT awd
Re: Removed Lower Shroud Can not get it back it
Postby WoodButcher » June 1st 2015, 1:51pm
I replaced my '97 w/ an elec fan years ago but IIRC it hooked on the front bottom and had a couple bolts that held it to the upper shroud.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 513
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Ken2.7 » June 1st 2015, 3:51pm
I struggled to get mine out and finally used an oscillating saw to cut off the 2" I was going to remove for my lift. Afterward it slipped in and out easily. I don't know how desperate you are and I don't know if you would have to remove the full 2". If you go this route put some scrap sheet metal between the shroud and belts/hoses so the vibrating blade doesn't hit them. Ken
viewtopic.php?f=40&t=74866
Ken2.7
Years of Membership: Ken2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full years
Topics: 32
Alias (AKA): Ken
Extra Info: AWD Provan Tiger GT
It is currently November 28th 2020, 12:49pm
Dbleeger
Comments: 13
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
