1999 safari passlock
Postby ninetwelver [OP] » July 2nd 2015, 8:48pm
Hello again. By a quirk in the universe I have gotten my safari back. But I am having problems with the pass lock. tried to reset by leaving key on position for 10 minutes shut off then turn back on till security light shuts off.
Dealer tells me that some sensor is burned out in steering column. but my keys do not have chips in them. also noticed that electric door locks dont work. Dealer says in will be $500.00 to fix.
Thanks in advance you folks have always helped.
steve
ninetwelver
Years of Membership: ninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full yearsninetwelver has been a member for 7 full years
Alias (AKA): steve
Re: 1999 safari passlock
Postby Leeann_93 » July 3rd 2015, 12:06am
Passlock Relearn:
Turn the key to Run, then VERY BRIEFLY turn it to start - do NOT let the van start - and back to Run. Leave it in Run for 10 minutes; the Security light will flash for the full 10 minutes (mine turned solid for the last 10 secs or so before it went out). When it goes out, turn the key to Off and wait 10 seconds. Do it again - turn to Run, briefly to Start, back to Run for 10 minutes. Turn the key to Off, wait 10 seconds. Do it again. This time, when you turn the key to Run, the Security light should be solid as normal and the van should start and continue to run.
Had to do this when I did ignition switch/lock cylinder replacement on my '99. My keys aren't chipped, either.
However, if your key is worn, no amount of Passlock relearn will help. You'll need a new key, one not cut as a copy of the old one. Dealers will cut a new key from the VIN if you show proof of ownership.
Postby Leeann_93 » July 3rd 2015, 12:09am
Forgot to add:
I have pics and descriptions of my work on the '99 here:
viewtopic.php?f=9&t=10966&start=280
As for the door locks, make sure the fuses and relays are in working order, then check the wiring to the driver's door.
Postby Meterpig » July 3rd 2015, 12:37am
ninetwelver wrote:Hello again. By a quirk in the universe I have gotten my safari back. But I am having problems with the pass lock. tried to reset by leaving key on position for 10 minutes shut off then turn back on till security light shuts off.
steve
$500...for real? :eek: :screaming: :banghead:
This is why most people hate dealers.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby Lumpy » July 3rd 2015, 1:02am
Mine has college girls in short pants and tank tops working as Valets when you pull up to the service dept. They still charge too much though.
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Postby ninetwelver [OP] » July 3rd 2015, 2:50am
I know it set me back when he said that. He was so sure how to fix. It appears to possibly be the key. BUT is there any truth in there statement that a sensor is bad in the column?. :liar:
ninetwelver
Alias (AKA): steve
Postby Coe1979 » January 3rd 2020, 8:24pm
What wound up being the issue?
Coe1979
Years of Membership: Coe1979 has been a member for 1 full year
Alias (AKA): Coe
Extra Info: 4.3 RWD
Postby AstroWill » January 3rd 2020, 11:29pm
OP hasn't been around for 6+years, probably won't get much in the way of a response from him.
Topics: 109
Images: 473
It is currently April 23rd 2021, 7:27pm
Comments: 38
Date: Today
Time: 3:30am
Attached by: Birdshake
BirdshakeBirdshake is online!
Time: 4:13pm
Jack.buster.05
Time: 5:30am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 38
Date: Apr 06 '21
Time: 11:08pm
