Distributor wires
Distributor wires
Postby smokinjoe [OP] » August 12th 2015, 9:04pm
I am trying to replace the wires going from the distributor to the coil. Does anyone know where I can get those besides junk yard?
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
  • Distributor brand/from?
    by DriveDog » November 18th 2020, 10:33pm in Electrical
    Last post by dchan51360 View the latest post
    November 25th 2020, 1:06am
    December 4th 2020, 7:03pm
Re: Distributor wires
Postby CopperFiremistCopperFiremist is online! » August 12th 2015, 11:25pm
Should be able to get a new pig tail or hit the JY
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby smokinjoe [OP] » August 13th 2015, 6:27pm
Went to 25 junkyards and no dice. I have put many days into this fix with no avail.
Doesn't anyone sell these new?
smokinjoe
Topics: 268
Extra Info: RWD
Postby Sailing_Faith » August 13th 2015, 6:41pm
Wow! 25 yjs! What's going on? Are they just selling the harnesses with the motor?
Did you unwrap and inspect each wire? Pull on each one where it goes into the connector?
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby RECox286 » August 13th 2015, 10:50pm
If you are having a problem with the coil lead, why not do the right thing
and replace the hi-tension wire set with a new, good quality, direct fit
replacement set. Not all that expesive, and probably a swell idea to boot.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Lumpy » August 13th 2015, 11:11pm
smokinjoe wrote:Went to 25 junkyards ...
Honestly?
In what area are there 25 junkyards?
Postby smokinjoe [OP] » August 13th 2015, 11:20pm
Well, here in NYC there is little Tiajuanna by Citifield stadium. Will try to post pics but there are way more than 25 junkyards all in one place.
They had whole motors but they were not easy to get to so they wanted $75 for the coil and wires. (no way)
I already replaced the hi tension wires to no avail and its the 2 lower volt wires that may be partially to blame.
Will continue to find a real mechanic to try to fix this ridiculous misfire . Today am doing the fuel filter and putting anti foul shrouds on 2 plugs.
smokinjoe
Topics: 268
Extra Info: RWD
Postby RECox286 » August 14th 2015, 2:43pm
Sorry, misunderstood. Sounded like the secondary coil wire was the problem.
You should be able to salvage what you need from any 4.3 L Chevy, or get new
pins from the LAPS and rewire the bugger using the existing connector shells.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
It is currently December 4th 2020, 7:03pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
