Best distributor cap?
Postby smokinjoe [OP] » August 15th 2015, 3:46pm
So I am wondering if the quality of dist cap will affect my results.
I found this one that someone on here raved about but its $54
http://shop.advanceautoparts.com/p/acce ... ibutor+cap
Then rockauto has the acdelco for only $10(!)
I have a store brand advance auto one on now and am wondering if I really believe in it.
Do I try the octopus one?
Every thread on misfire I read it says change cap & rotor again even if you think they are good.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
  • Distributor brand/from?
    by DriveDog » November 18th 2020, 10:33pm in Electrical
    Last post by DriveDog View the latest post
    December 9th 2020, 11:45pm
    9
    59
    January 23rd 2021, 6:06pm
Re: Best distributor cap?
Postby WoodButcher » August 15th 2015, 5:23pm
Joe, that's for a gen II not the '95
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Tegnus » August 15th 2015, 5:33pm
I bough AC Delco cap from RockAuto for our 2004 Astro and haven't had any trouble for last 2.5 years (~25k miles).
2004 Astro AWD (Astrid), 3" Lift, BFG All-Terrain T/A KO2 LT225/75R16, Tru-Cool LPD-4490 Trans cooler, ARB Awning 2500 (ARB4401A)
Follow us on Facebook and Instagram | Check out the build of our 2004 Chevy Astro AWD "Astrid"
Tegnus
Years of Membership: Tegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full years
Topics: 38
Images: 6
Postby smokinjoe [OP] » August 15th 2015, 6:35pm
If they make this one for my van is it better? I am trying to improve ignition to fix a misfire and the one I have is store brand.
I figure AC Delco would be an improvement too right?
smokinjoe
Topics: 268
Extra Info: RWD
Postby Lumpy » August 15th 2015, 6:53pm
ACDelco with BRASS (not aluminum) contacts is the typical cap discussed as "best" around here. There may be other brands with brass terminals that are just as good. There are apparently some with crummy plastic that crumbles or doesn't insulate as well or is more prone to developing carbon tracks or something.
It's probably important to remind ourselves that the "Best" cap is the one that's "Good enough". We don't gain performance from a dist cap, no matter what the manufacturers say or the ricers believe. A better cap probably means it lasts longer than a less than better cap.
If there's a dist cap related ignition stumble, probably ANY new cap, no matter what quality, will resolve it for SOME time period. Better caps will keep it resolved longer.
If you're working on your distributor, be sure to do the "Baseplate screen removal" thing that was in the factory service bulletin.
Postby Leeann_93 » August 15th 2015, 7:11pm
No, they don't make a flat cap for Gen Is. And be glad they don't.
Get a cap with brass terminals. Standard's Blue Streak used to have brass; I have no idea if they do any more, but they worked great on my '93.
I wouldn't use any LAPS house brand. I even had massive problems with NAPA/Echlin caps on my '93 and switched to Blue Streak.
Postby gavio » August 15th 2015, 7:20pm
I've read that statement on this forum in a few places (from a couple different folks), and as far as I can tell, AC Delco does not make a cap with brass contacts any more - at least not that I've been able to find....
gavio
Topics: 77
Images: 4
Postby Lumpy » August 15th 2015, 7:50pm
gavio wrote:
... as far as I can tell, AC Delco does not make a cap with brass contacts any more - at least not that I've been able to find....
This is what fits a Gen I. Not sure about your year -
http://www.amazon.com/dp/B0013FTZTS
Postby gavio » August 15th 2015, 9:12pm
Well, I'm glad they make SOME cap with brass contacts..... Sadly, no, that style does not fit the Gen2 vans....
gavio
Topics: 77
Images: 4
It is currently January 23rd 2021, 6:06pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
