Got 95' Astro Van has new alternator and good battery.
Tested the battery twice came out good.
Change the alternator twice in 1 week.
Worked fine at first after running. Not sure if front and back a/c
and turning headlights are causing the battery light to turn on
and the voltage to drop low. Sometimes voltage gets normal but then drops again.
Could I directly run a wire from the positive of the battery
to the alternator?
Any reason why I got this problem?
