Another 95 Starting Problem
Postby bramwell40 [OP] » August 10th 2010, 1:24am
Hello all, again;
You were all so very helpful before I thought I would at least ask for some help before delving any further into this.
About a year ago, we developed a parasitic drain on the battery. Some days we would come out and the van would start up fine; other days the battery would be dead. I had a mechanic look at the starting circuit to diagnose any problems there, but there were none. There is just a constant drain on the system. So, he installed a knife switch on the positive terminal of the battery so each time we stop for any period of time, we disconnect the battery.
After about six months of this, the van started to have problems starting the first time in the morning, but after that it would start up immediately. As days went by, it started having more and more problems starting throughout the day. Then, it would not start at all. I continued to try it for about fifteen minutes and finally got it started. I headed right to the mechanic and ask him to investigate. There were no engine codes, and no other problems except it needed a tune up badly. So, everything was replaced: coil, cap. plugs and wires, ignition module, etc. Then it would start up again like a dream. This continued for a couple of weeks, and then the early morning starting problems, which then disintegrated to no starting at all. It cranks fine, but my wife tried today to start it for about twenty minutes to no avail but a run down battery.
My mechanic saied that they checked the fuel pressure, and it was great cause I had immediately wondered about the fuel pump.
So, any thoughts? I don't know if I need a new pcm, or what. If you have encountered this before, maybe you will be willing to enlighten me.\
Thanks for the time.\
Dave
1995 GMC Safari, 6 cyl. 4.3 L type W engine with 191585 miles, AWD
bramwell40
Years of Membership: bramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full yearsbramwell40 has been a member for 10 full years
Extra Info: 4.3L AWD
  • Another Rear Defrost ??
    by Lowcountry » December 9th 2020, 7:08pm in Electrical
    Last post by Lowcountry View the latest post
    December 10th 2020, 11:07pm
  • another turn signal post
    by paulbot » January 21st 2021, 1:12am in Electrical
    Last post by paulbot View the latest post
    January 25th 2021, 1:20am
    66
    April 21st 2021, 9:09am
Re: Another 95 Starting Problem
Postby LEVE » August 10th 2010, 1:31am
What's it missing, spark or fuel? Spray some starting fluid into the air intake. If is starts, it's fuel related. If not, it's ignition related.
LEVE
Years of Membership: LEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby bramwell40 [OP] » August 10th 2010, 1:52am
That is what had my mechanic puzzled. According to him, spark is great and fuel is great. He finally said that if the tune up didn't take care of it, then I would probably have to take it to a dealer that might have more insight. I really wanted to avoid that because the cost is so much.
Some times it starts with the first turn of the key; other times it would take 5 minutes of off and on cranking. today, it wouldn't start at all. The intermittent nature of this just drives me nuts.
I will try the starting fluid in the intake to see what happens.
Thanks
Dave
bramwell40
Postby webcat » August 10th 2010, 1:59am
Not saying that this is your problem but something to think about , when you try to start the vehicle all the time and it does'nt start but you keep trying it gets fuel on your spark plugs and ruins them.
Edit , sorry i did'nt see that you got a tune up.
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Big_kid » August 10th 2010, 2:53am
webcat wrote:...it gets fuel on your spark plugs and ruins them.
Doesn't matter how old the plugs are. Ruined is ruined, new or old. Been there, done that, learned the $20.00 lesson.
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby bramwell40 [OP] » August 10th 2010, 3:51am
So, maybe this is all a cascading problem. Because of the parasitic drain on the battery, the battery is disconnected each time we stop. The pcm then loses all information and has to relearn it. So, each time we start, the mixture is off, and may be fouling the plugs. That may be why it starts so quickly with new plugs, but as time goes on, it is harder and harder to start. Then, when the plugs become totally fouled, it will not longer start.
So, I have to go back to the beginning and find where the drain is coming from and fix it so I don't have to disconnect the battery anymore. Does that make sense?
Dave
bramwell40
Postby Matrixx » August 10th 2010, 12:31pm
Hi bramwell40
I would look for the drain first as well, get that sorted out and maybe the rest will fall into place (back to normal). You might want to check the glove box for the drain. I had this problem one time and found out I didn't close the glove box properly one night (and the light was still on inside) and it drained the battery over night.
Another place to check is the cigarette lighter, I had the lighter element itself short out and put a drain on the battery. If their is any metallic objects that has managed to find it's way into the lighter chamber, that will short and put a drain on the battery.
All 3 things I have mentioned here, has happened to me. Just a couple of easy places to check first before digging into it.
Also check the luggage Compartment light as well.
Let us know how things are progressing, thanks.:)
PS: Just to clarify here, is that their is "normal" parasitic drain with the newer vehicles. This comes from the computer and radio as it's always fed memory power with or without the ignition being on.
Normal Parasitic Drain is around 7 to 12 mA.
Maximum Parasitic Drain should be around 30 mA (0.030 amps).
Matrixx
Postby kennyj » August 11th 2010, 5:15am
I had this exact problem with my 93 G20 van with a parasitic drain on the battery. If it was parked for more than a week I would notice it in starting. Then in the winter after being parked the battery went fully dead and froze. I replaced it with a new battery and started doing something like you, if the van was going to be parked for more than a day I would disconnect the battery. I never did sort the problem, I got my Astro and the G20 went to the junker.
I believe your year van has a power distribution block near the battery, with a main battery lead and a number of circuit feed wires lugged and bolted onto a terminal block. I would loosen these up and one by one see if any of the feed wires are drawing a noticeable amount of current; you may even see a little arcing from one of them. Or you may need to use a meter to check current draw on each line. Like Matrixx said, a few milliamps would be normal like for the radio or pcm, but anything more than about 30 milliamps would cause a noticeable drain on the battery. Just for reference a single dome light bulb draws about 50 milliamps. If you can isolate a wire that's drawing excessive current then you can start to narrow it down to what part of the van's electrical system that wire feeds.
kennyj
Blue Status (L2)
Blue Status (L2)
Years of Membership: kennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full yearskennyj has been a member for 11 full years
Topics: 41
Alias (AKA): Kenny
Extra Info: 250k+ miles
Postby bramwell40 [OP] » August 14th 2010, 5:15pm
Hello all,
Just as an update I thought I would tell you that I took my multimeter out to the van. I placed in inline on the knife switch that is installed to disconnect the battery. I would get a reading of .25 amps. I then started removing fuses one at a time. Nothing happened until I came to the cigarette lighter, dome light circuit. When i removed that, it dropped to zero. This is the block that keeps the clock in time, and powers the dome lights and cigarette lighter. I looked inside the lighter to see if something had dropped inside, but no luck. So, now I need to trace where this drain is coming from on this circuit.
Thanks for all the help.
bramwell40
Postby chevy57bert » August 14th 2010, 9:34pm
I would like to know. what the Max amp drain is?
With engaged Ignition and without....
Thanks Bertjuh.
chevy57bert
Section Moderator
Section Moderator
Firing on 8 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby bramwell40 [OP] » August 14th 2010, 10:35pm
Well. with the ignition dis-engaged it reads .31
with the ignition engaged it tops at 11.29
This is with the meter set to read dc amps set at 20A
bramwell40
Postby chevy57bert » August 14th 2010, 10:44pm
bramwell40 wrote:Well. with the ignition dis-engaged it reads .31
Thanks. I write it down.
It`s nice to know, if your battery drains out every day :mrgreen:
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
It is currently April 21st 2021, 9:09am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
