Ignition & Headlights
Postby LaundryMonster [OP] » August 15th 2010, 5:54am
Im trying to work out if my ignition and head lights are contributing to my car quitting issues.
I turn the ignition to accesories and the parking lights come on.. but the head light dial is turned to off .. i push the dome over ride button but it does nothing, During all this the intetiot lights are not on.
I turn the car over and it starts.
I turn the car all the way off and pull the key out but the radio clock is still on..
I put the key int, turn to accesories and then turn the car all the way off again the clock radio turns off and the key comes out
Does this sound normal?
Thanks
edit - I just noticed when i turn to accesories, the fuel pump primes and then for about 10 seconds after i hear what sounds like a series of clicks .. i dont know if this is electronic or if its just fuel going through the line
also when i start the engine i dont see any major spars.. however looking in pitch black dark i can see 2 faint blue sparks comine from the north and north west sides of the thing where the leads connect into (the cap?)
again i assume this is normal ?
1998 Chevy Astro - (2WD / 5001-6000-Hydraulic / [L35] 262 ci V6 4.3 MFI)
Problems - Damaged Cat / Broken Gas Gauge / Car Randomly Quits while driving
LaundryMonster
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: LaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full yearsLaundryMonster has been a member for 10 full years
Extra Info: 2WD V6 4.3 MFI
Re: Ignition & Headlights
Postby Astroplane » August 15th 2010, 7:38am
This sounds like an ignition switch problem. When was the last tune-up with wires, cap, and rotor?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby TheRealDaddy » August 15th 2010, 1:02pm
I agree, I'd be looking into the Ignition switch that is mounted on top of the steering column for your strange electrical happenings. However the parking lights issue has me a little puzzled. Maybe you should try removing the radio temporarily and see if you still have issues. I'm not exactly sure how that would be causing the problem but its the only device that I can think of that has wiring from the accessory circuit and the lighting circuit both. It might also be possible that your vehicle has an aftermarket daytime running light circuit, although if it does somebody wire it in incorrectly because it should be connected to the headlights not the parking lights. Also check under your dash for a remote start module. If it has one it's going to probably be hanging under there all hap-hazardly by zip ties or something else odd because those weren't factory equipment. If it does have one of those try unplugging it and removing the bank of relays that accompany it. These after market devices were nice for a moment but most of them didn't last all that long and often caused strange electrical issues. Without looking at your van directly electrical problems can sometimes be very hard to diagnose but these are some of the things I can think to look for.
Also as stated previously give that thing a tune up. Cap, rotor, wires, should take care of your arcing. (while your at it just change the plus and you've got a fresh ignition system.
Good luck
Please just call me Carter
current modes of transport:
91 GMC Safari XT 5.7 350
89 GMC Safari 5.7 350
83 Honda Shadow VT750C
78 Chevy El Camino (still in progress)
99 Hyundai Accent
08 Roketa JM Star touring scooter
TheRealDaddy
Years of Membership: TheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full years
Topics: 7
Alias (AKA): Carter
Extra Info: XT 5.7 V8 2WD
Postby LaundryMonster [OP] » August 15th 2010, 5:44pm
Not sure when the last tune up was, but according to the previous owner (i only purchased the van a week ago) .. it was done in the last month.
but then again, no Idea how true that is.
Ill have a poke around today and see what I can find..
LaundryMonster
Fueling (5/8 tank)
Fueling (5/8 tank)
Postby LaundryMonster [OP] » August 15th 2010, 10:05pm
according to my room mate the light thing is normal?
in canada its apparently law to have your lights come on when you start the car. odd
Had a look under the dash and couldnt find anything out of the ordinary. no big zip tied boxes.
however I did find a plug that was not plugged in, and I cant find where it goes.
Also today, during the day time I couldnt get the kind of clicking noise to happen again.
This is really driving me nuts. Ill try and get some photos so you can see what im talking about.
LaundryMonster
Fueling (5/8 tank)
Fueling (5/8 tank)
It is currently November 29th 2020, 8:25pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
sixsixsixsix is online!
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
