rear lift gate dome light switch
Postby timothy47130 [OP] » October 11th 2015, 7:10pm
Has anyone found a place that sells just the dome light switch that's on the lift gate support strut ? I have disassembled mine and it has one set of brass contacts broken in it . I have also gotten 1 from the salvage yard that has the same problem . and the other 2 I checked at the salvage yard were broken also . Im going to try to take 2 and make one . They have 2 sets of contact sweeps like a fuel pump sender arm in them . Between the 2 I should be able to solder parts in to make one . Oh crap I just gave myself an idea talking about a fuel pump sender . Maybe I can use the brass sweep off my old fuel pump sender to fix it . I guess we will just have to see . 8-)
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Extra Info: mark III conversion
  • Rear hatch lock switch
    by Rinny » May 5th 2020, 1:43am in Electrical
    July 8th 2020, 5:19am
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    October 12th 2020, 10:54pm
    61
    October 22nd 2020, 7:59am
Re: rear lift gate dome light switch
Postby AstroWill » October 11th 2015, 8:55pm
Or you could replace it with a magnetic type switch.
Topics: 106
Images: 438
Postby smokinjoe » October 12th 2015, 12:45am
I have the same issue. Where is the switch and where would you find a magnetic one?
I miss not having the light come on.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby timothy47130 [OP] » October 12th 2015, 1:02am
It is now fixed I used 2 to make one. I will post pics later.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby AstroWill » October 12th 2015, 3:06am
Amazon, ebay, RadioShack, lowes, homedepot etc etc. LOL, probably $1 shipped from china.
Topics: 106
Images: 438
Postby timothy47130 [OP] » October 28th 2015, 9:10pm
Sorry it took so long to post pics. I was off work on vacation for a week. But anyways here is how I used 2 dome light switches and a little soldering to make 1 good one switch. I will try to upload the pics off my phone tonight.
Last edited by timothy47130 on October 29th 2015, 12:09pm, edited 1 time in total.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby timothy47130 [OP] » October 29th 2015, 12:08pm
Here is the switch repair tutorial that anyone with just basic soldering skills can do. I suppose if you don't have any soldering skills you could just tightly wrap the wire around were I soldered it on. It wouldn't be any were near as reliable as soldering it on, but I'm sure it would work for a while.
Both switches had one side of the little brass fingers/ contact sweeps corroded off. Every one out of the 5 I pulled at the salvage yard was this way. I suspect this is the constant Hot side of the switch and thats why it corroded off
The o-ring shown is all that hold this assembly into the outer plastic tube. The o-ring is also what hold the contact sweeps in. If you unsnap the little cover were the wires come out of the switch, and spray the inside of the black outer tube with a little wd40. The internal switch assembly shown slides right out with the push of a screwdriver from the wire end of the tube.
Remove the o-ring on the (parts switch) and pull out the little brass contact sweep. Next clean up the contact ends of both contact sweeps that will be on your good switch with a scotch brite pad or fine sand paper. Also clean up the wire end of the contact sweep you going to solder. Then solder your wire back on the salvaged contact sweep, and Reinstall both of them as shown with the o-ring holding them into the good switch. You might have to bend the contact end of them in just a tad to make sure they contact the metal ring thats inside the switch to properly work (sorry no clear pic of the metal ring but you cant miss it)
Push it all back into the outer tube, and snap the cover back on the wire end of the switch. When properly assembled the switch end should stick out as shown. I recommend the next step but its optional. You can hook up your multi-meter and cycle the switch while you test it for continuity ( so you know it works before you reinstall it). Then all thats left is to reinstall the switch on the lift support. And if all went well you can finally see what you are trying to find in the back of your van at night.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby WoodButcher » October 29th 2015, 2:04pm
On my to-do list, thanks Tim!
WoodButcher
Firing on 4 Cylinders (L6)
Topics: 30
Images: 512
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby timothy47130 [OP] » October 29th 2015, 7:38pm
It really don't take long to do it either. And while it might seem like a small thing. It is one hell of a help at night. I was playing the run to the front of the van game. Opening a front door to get the dome light to come on. Then running back to the back of the van. And let me tell ya that gets old quick.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby AstroWill » November 4th 2015, 5:34am
A 12volt version of 'The Clapper'?
Topics: 106
Images: 438
Postby timothy47130 [OP] » February 24th 2016, 9:27pm
Just a quick update. My lift gate dome light switch repair is still working and has held up well.
all stock besides-
dual exhaust
timothy47130
Topics: 41
Images: 7
Alias (AKA): Tim
Postby Don1806 » February 24th 2016, 10:42pm
AstroWill wrote:A 12volt version of 'The Clapper'?
I think Lumpy made his own version of that, but every time he ate beans the dome light wouldn't shut off. :confused:
Nice job on the switch repair. When you think about the beating that switch takes from the liftgate, no wonder the ones in the junk yard were all broken.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full years
Topics: 18
Images: 2
Alias (AKA): Don
Extra Info: AWD 170K
It is currently October 22nd 2020, 7:59am
nwisehart
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
