Headlights on when van started
Postby brickren [OP] » September 15th 2010, 2:53am
Hello. I would like to have the headlights only come on when I want them on. I have a 2000 Astro 2wd. Is there a simple way to change wiring so that lights are not always on? I installed these lights, http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT. They look great and the halo looks cool, but with lights on all the time, there is no chance to see them. I wired them up to turn signal lamp. Thank you for your help. Brian
brickren
Years of Membership: brickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full yearsbrickren has been a member for 10 full years
Re: Headlights on when van started
Postby ihatemybike » September 15th 2010, 3:57am
That font makes my eyes hurt.
You could pull the DRL fuse.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby astroturf » September 15th 2010, 4:13am
brickren wrote:Hello. I would like to have the headlights only come on when I want them on. I have a 2000 Astro 2wd. Is there a simple way to change wiring so that lights are not always on? I installed these lights, http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT. They look great and the halo looks cool, but with lights on all the time, there is no chance to see them. I wired them up to turn signal lamp. Thank you for your help. Brian
Without a Pic... It didn't Happen.
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby TheRealDaddy » September 15th 2010, 4:36am
Depressing your parking brake will cancel out your daytime running lights. This way you can see your cool lights when you are parked. If you depress the pedal one click only you can usually drive with the lights disabled. Be very careful however if you do this because it can warp drums if it causes friction. You might be able to add a manual switch to the barking brake wiring to achieve the same effect without depressing the brake however, I'm not entirely sure that this might not confuse the brake system anyway. Your van I'm sorry to say is just a little newer than I am used to dealing with.
If you are familiar with relays you might be able to wire in one between the headlamp power and the lights using the normally closed side of the relay. This way your headlamps would function normally unless you supplied power to the relay and then the lights would go out.
However you work it, realize that daytime running lights are a safety feature and it is not legal in most places to disable safety features. If you happen to drive past a cop who knows that you are supposed to have daytime running lights on your van he could pull you over and ticket you. (I actually know a guy that had it happen) I'm not saying this is very likely but it is something to think about.
Please just call me Carter
current modes of transport:
91 GMC Safari XT 5.7 350
89 GMC Safari 5.7 350
83 Honda Shadow VT750C
78 Chevy El Camino (still in progress)
99 Hyundai Accent
08 Roketa JM Star touring scooter
TheRealDaddy
Years of Membership: TheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full yearsTheRealDaddy has been a member for 10 full years
Topics: 7
Alias (AKA): Carter
Extra Info: XT 5.7 V8 2WD
Postby rev_les » September 15th 2010, 10:06pm
X2. It's the easiest way and everything still works normal otherwise.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby ShAgSTRO » September 16th 2010, 1:12am
pull that darn fuse. Whenever I needed a quick getaway in the tahoe, i would always press down on the e-brake pedal one click...my friends don't like riding with me anymore...
1986 Astro...I like my EFI carb ;)
ShAgSTRO
Years of Membership: ShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full years
Topics: 16
Extra Info: 4.3L
It is currently January 24th 2021, 10:28pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
