Replace the alternator, it should be such a simple job
Postby andrew678122 [OP] » December 21st 2015, 9:16pm
I had to replace the alternator on my Astro.
1. Got a rebuilt from Autozone, put it on and the headlights flicker, the voltmeter flickers, it has to have a bad diode.
2. Got a replacement rebuild, it doesn't work at all.
3. Got another replacement rebuild, yay it works!
4. Kinda. Every so often this alternator goes up to ~20 volts. I shut the van off start it, shut it off, start it... after a dozen or so iterations it's back to normal.
5. But it's intermittent, most of the time it's okay, just that occasionally it goes into 'let's fry the electronics' mode.
To my way of thinking about the only thing that could cause this is a bad regulator, in other words I need a new alternator. Is there anything else that could cause this?
678122
andrew678122
Years of Membership: andrew678122 has been a member for 6 full yearsandrew678122 has been a member for 6 full yearsandrew678122 has been a member for 6 full yearsandrew678122 has been a member for 6 full yearsandrew678122 has been a member for 6 full yearsandrew678122 has been a member for 6 full years
Topics: 28
Images: 16
Alias (AKA): 678122
Extra Info: cargo van AWD
  • alternator info everyone should read
    by markmitch » July 28th 2020, 8:04pm in Electrical
    July 29th 2020, 2:56am
  • Good High End Alternator?
    July 4th 2020, 2:16am
    81
    December 1st 2020, 12:40pm
Re: Replace the alternator, it should be such a simple job
Postby RECox286 » December 21st 2015, 9:57pm
You will find that Delco alternators have a built-in regulator. Quit fooling with aftermarket rebuilds from the "discount" stores and
find a real automotive electric shop that does their own rebuilds, OR, look for a real, new, not fooled with, unit. I always delt with an
independant (once found not dismissed) who always wasn't the cheapest, but always supplied the best in services and hardware.
I suggest you do the same.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Zebediah III » December 22nd 2015, 12:01am
Voltage above 15.5 is where the ECM gets damaged.
Big mega chain Chairman Mao parts stores have big
discounts and sell junk. You will get plenty of parts-changing
practice. I feel your pain. Good parts are getting hard to
find. I have had good luck with new made in Mexico alternators.
Napa has them. Car Quest did have them, but they were bought
by Chariman Mao Discount People's Republic Auto Parts. Napa
will be gone in a couple years. If you buy online ask lots of
questions like "country of manufacture". If they won't answer,
don't buy anything from them. Your vehicle, and peace of mind
is only *** good as the parts you put on it, and THAT is the
dilema anymore.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby timothy47130 » December 22nd 2015, 12:57am
Welcome to my world. Nothing is ever easy when I work on a vehicle. The simple fixes always end up taking 2x longer. And for some reason the difficult fixes always seem to go faster than they should. :confused:
Back on a serious note. Have you checked all your grounds? A bad ground wire connection will cause all kinds of crazy crap to happen. It might be worth a look.
Tim
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Extra Info: mark III conversion
Postby andrew678122 [OP] » December 22nd 2015, 2:50am
My van is pretty clean, no rust (it's an El Paso vehicle), very little dirt, and I do all of my own maintenance, so I can vouch for most of it. But I will double check it. I went ahead and ordered a new ACDelco alternator from Amazon, $187, and my local AutoZone said they would take their rebuilt alternator back and give me a refund.
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby AstroWill » December 22nd 2015, 3:03am
andrew678122 wrote:no rust (it's an El Paso vehicle), very little dirt
Little dirt, ELP is one giant dust ball. You only drive it in tunnels down there or what? LOL Buy your filters cheap on RA in bulk :)
I put ~80,000miles on my last Autozone rebuilt alternator so I can't say anything bad about them, and it's still going. But 3 'bad' in a row would have me worried, or it's something else...
Images: 443
Postby andrew678122 [OP] » December 22nd 2015, 3:43am
Yeah it is very dusty, but the wind blows it away. And it sandblasts the cars, cleans off dirt, paint, and the top layer of metal...
Re the alternators, the failure mode was different in each...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Mmusicman » December 22nd 2015, 4:09am
The last alternator I bought (from Pepboys) I had to special order, and when it arrived it wouldn't even spin (new in box). The 2nd unit was fine. Labor to change only took 5 minutes, but several drives back and forth cost me about an hour.
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby andrew678122 [OP] » December 25th 2015, 8:31pm
I got my new alternator, but it's a little different from the one I took off. It's a bit bigger in diameter, pulley is slightly smaller, etc. I put it on knowing that it was a little different, I didn't realize how different until I went to put the belt on. It was a bear getting it on, and the spring loaded tensioner is just about at the limit of it's travel. I think the alternator they gave me is the 145 amp instead of the original 105 amp. The connector comes out the side instead of the back (actually better).
Anyone know what serpentine belt I need? I'd think a belt an inch longer would do but I'm not sure...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby AstroWill » December 25th 2015, 8:41pm
You can measure it yourself, but an inch EDIT: LONGER should help a lot. You definitely don't want it too tight.
BTW, they have a white 3rd gen over at LKQ if you need any 3rd gen specific stuff.
Images: 443
Postby andrew678122 [OP] » December 25th 2015, 9:46pm
AstroWill wrote:You can measure it yourself, but an inch shorter should help a lot. You definitely don't want it too tight.
LKQ???
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Corsemoto » December 25th 2015, 10:09pm
The 2005 Astro alternator is slightly different from previous years. The alternator with the connector at the back was probably correct for your 2005, previous years had the side connector but they are both AD230 alternators so not sure what, if any difference other than housing/connector location. They are 4-pin on the alternator but two-pin plugs.
The AD244 would be bolt-in higher output 145 amp alternator and usually has larger pulley. There are some threads here that use that alternator and mention different belts that work.
https://www.astrosafari.com/viewtopic.php?f=76&t=14522&hilit=belt+length
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby AstroWill » December 25th 2015, 11:51pm
andrew678122 wrote:
AstroWill wrote:BTW, they have a white 3rd gen over at LKQ if you need any 3rd gen specific stuff.
LKQ???
Guess you don't visit your local junk yards. They are having a 40% off sale the 1st to the 3rd.
Images: 443
Postby Mmusicman » December 25th 2015, 11:57pm
andrew678122 wrote:Anyone know what serpentine belt I need? I'd think a belt an inch longer would do but I'm not sure...
Part numbers typically correlate to the length. Should be easy to go up one size.
Dayco for my 2000 is: 5060870 (87.0" belt)
Dayco... 1/2" longer: 5060875 (87.5" belt)
Dayco... 1" longer is: 5060880, (88.0" belt)
See the pattern. This is just an example... but most belts follow similar part numbering schemes.
Topics: 73
Images: 49
Postby andrew678122 [OP] » December 26th 2015, 12:20am
AstroWill wrote:
LKQ???
My local Junque Yarde is on Montana, and it has been a few months, maybe 6 even. The last time I went through there I looked at every Astro/Safari they had and pulled off everything I could think of...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby AstroWill » December 26th 2015, 12:24am
andrew678122 wrote:
AstroWill wrote:Guess you don't visit your local junk yards. They are having a 40% off sale the 1st to the 3rd.
LKQ is on Montana, 13200 Montana Avenue El Paso, Texas 79938
Images: 443
Postby andrew678122 [OP] » December 26th 2015, 12:43am
Maybe that's what I need to do, go to some more junkyards and see if I can find a Tiger there and rip out all the good bits...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Mmusicman » December 26th 2015, 12:43am
andrew678122 wrote:LKQ???
Got them here all over Florida too.
Topics: 73
Images: 49
Postby AstroWill » December 26th 2015, 1:27am
andrew678122 wrote:LKQ is on Montana, 13200 Montana Avenue El Paso, Texas 79938
Maybe that's what I need to do, go to some more junkyards and see if I can find a Tiger there and rip out all the good bits...[/quote]
As a proud owner of a Tiger, and a frequent visitor of junk yards, I can pretty much guarantee that you are more likely to get struck by lightning in a cave then to find a Tiger in the JY there. They do have a couple of RVs that you can look at, pretty tore up though.
Images: 443
Postby andrew678122 [OP] » December 26th 2015, 5:19am
I usually go to Pull-a-part but I'll give LKQ a shot. I would love to find a pop-top I could re-purpose... I'll wear my rubber boots...
My son said he'd give me a lift to AutoZone tomorrow am so I'll get a belt and be back on the road...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
It is currently December 1st 2020, 12:40pm
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
