turn signals flakey
turn signals flakey
Postby since_1971 [OP] » September 30th 2010, 2:08pm
I have been having an intermittent problem with the turn signal switch, some times the directionals don't work, or blink slowly.
some times it's when it rains, but not always.
I'm ok for now because nobody else uses there blinkers here in Providence, but I might want to fix it esp if I drive to the 'burbs some time.
any ideas
since_1971
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: since_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full yearssince_1971 has been a member for 11 full years
Topics: 13
Alias (AKA): since_1971
Extra Info: cargo 2 wheel dr
  • E-brake warning light won't turn off
    by AngryPunk » November 12th 2020, 3:43pm in Electrical
    November 16th 2020, 6:37pm
  • No power when I turn the key
    by Travus123 » January 20th 2021, 8:07am in Electrical
    January 22nd 2021, 4:40am
    9
    39
    March 4th 2021, 11:30am
Re: turn signals flakey
Postby Phantom » September 30th 2010, 2:24pm
Check the flasher unit under the dash by firewall it may be going bad or the wrong one , it could also be corrosion buildup in the bulb sockets , or a bad ground connection.
Phantom
Firing on 7 Cylinders (L4)
Postby RECox286 » September 30th 2010, 3:38pm
X2 Bad flasher unit # 1 cause of slow flash. A really bad ground will usually bog the whole system to a grinding halt. Not really sure where they put the flashers, but I would trade them in on electronic ones. There are two flasher units, one for T/S and one for Hazzard. One way to troubleshoot the system: Turn on the Hazzard and if everything is pinky with that system, then swap flasher units. If the hazzards fail, and T/S work, replace the bad flasher. If no change, start looking for bad grounds, bulbs, wiring, or T/S switch.
Good Luck Y'all
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently March 4th 2021, 11:30am
OldSchoolNoe
Comments: 0
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 22
Date: Feb 17 '21
Time: 4:26am
