Removing the Rear Air switch
Postby Jhouserjr [OP] » February 3rd 2016, 7:26pm
My van has rear air conditioning. I have found that the power to the rear air switch is only on when the key is on and I want to use the circuit as a power source for an 'On Delay' relay that will feed power to to the main relay for a dual battery setup. I have never taken anything in the dash apart and need some guidance on removing the switch without breaking anything.
Thanks,
John
Jhouserjr
Years of Membership: Jhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full yearsJhouserjr has been a member for 10 full years
Topics: 21
Extra Info: AWD passenger
  • Rear hatch lock switch
    by Rinny » May 5th 2020, 1:43am in Electrical
    July 8th 2020, 5:19am
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    October 12th 2020, 10:54pm
    October 21st 2020, 2:34am
Re: Removing the Rear Air switch
Postby astroracer » February 4th 2016, 12:25am
It would be much easier to simply tap into the main fuse box under the dash. If you get in there and look at it you will see there are empty terminals that you can plug into for power sources. Use one labeled IGN. That will be an ignition on power source that will have only one circuit on it. The one you add. Use the correct terminals and fuse the new circuit appropriately.
Mark
1994 Astro with an LT1 350 (Ron Burgundy)
2004 Astro
2000 Monte Carlo SS
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Firing on 7 Cylinders (L1)
Years of Membership: astroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full yearsastroracer has been a member for 10 full years
Topics: 13
Alias (AKA): astroracer
Van Model Year: 1988
Extra Info: Major renovation
Postby Lumpy » February 4th 2016, 1:12am
I agree that it would be simpler, better practice to run a dedicated wire, fuse etc from fuse box south. Lots of room under that plastic threshold to hold wire(s).
But removing if you like, shouldn't be particularly weird, if yours is anything like my Gen I. Some typical plastic/metal connector gizmo. Squeeze something, pull something, it comes apart. Remaining avulsed appendage is safe to just hang in the dash. No exposed monsters.
It is currently October 21st 2020, 2:34am
nwisehartnwisehart is online!
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Users browsing this forum: No registered users and 20 guests
cron
