I have a 99 astro with the 4.3 motor and over 100k miles. I have gone thru 5 cam sensors in the last few months and cant figure out why. I will change it and the same day I get rough idle and the motor doesnt run right. The check engine light comes on and its the sensor again. I was told to replace the distributor but there is really nothing to them but the shaft and the sensor. Im tired of replacing the sensor and need some real help. I went from using autozone sensors to american standard sensors but its still the same. I just replaced one yesterday and right when I started the car it started running rough. I changed the coil thinking it may be surging too much power and killing the sensor but same thing. I checked voltage while the car is on and im getting 12 at the sensor and the ground is grounding. I even wiggled the plug to see if vibration was the issue. Someone told me to use genuine gm sensor but would that really make it work right? The american standard is what my mechanic uses and has said he has never had a problem with them. Please help im at my wits end.
